#include <Adafruit_Sensor.h>
This is an example for the TMP006 Contact-less Infrared Thermopile Sensor
Designed specifically to work with the Adafruit TMP006 Breakout
----> https://www.adafruit.com/products/1296
These displays use I2C to communicate, 2 pins are required to
interface
products from Adafruit!
#include <Wire.h>
#include "Adafruit_TMP006.h"
// Connect VCC to +3V (its a quieter supply than the 5V supply on an Arduino
// Gnd -> Gnd
// SCL connects to the I2C clock pin. On newer boards this is labeled with SCL
// otherwise, on the Uno, this is A5 on the Mega it is 21 and on the Leonardo/Micro digital 3
// SDA connects to the I2C data pin. On newer boards this is labeled with SDA
// otherwise, on the Uno, this is A4 on the Mega it is 20 and on the Leonardo/Micro digital 2
Adafruit_TMP006 tmp006;
//Adafruit_TMP006 tmp006(0x41); // start with a diferent i2c address!
Serial.println("Adafruit TMP006 example");
// you can also use tmp006.begin(TMP006_CFG_1SAMPLE) or 2SAMPLE/4SAMPLE/8SAMPLE to have
// lower precision, higher rate sampling. default is TMP006_CFG_16SAMPLE which takes
// 4 seconds per reading (16 samples)
if (! tmp006.begin()) {
Serial.println("No sensor found");
while (1);
Serial.println("Send s to enter sleep mode, or w to wake up. Measurements are not updated while asleep!");
// Check for sleep/wake command.
while (Serial.available() > 0) {
char c = Serial.read();
if (c == 'w') {
Serial.println("Waking up!");
tmp006.wake();
else if (c == 's') {
Serial.println("Going to sleep!");
tmp006.sleep();
// Grab temperature measurements and print them.
float objt = tmp006.readObjTempC();
//Serial.print("Object Temperature: ");
Serial.print(objt);
Serial.print("\t");
//Serial.println("*C");
float pump = tmp006.readPumpTempC();
//Serial.print("Pump Temperature: ");
Serial.println(Pump);
delay(400); // 4 seconds per reading for 16 samples per reading
@file Adafruit_MMA8451.h
@author K. Townsend (Adafruit Industries)
@license BSD (see license.txt)
This is an example for the Adafruit MMA8451 Accel breakout board
----> https://www.adafruit.com/products/2019
@section HISTORY
v1.0 - First release
#include <Wire.h>
#include <Adafruit_MMA8451.h>
Adafruit_MMA8451 mma = Adafruit_MMA8451();
void setup(void) {
Serial.println("Adafruit MMA8451 test!");
if (! mma.begin()) {
Serial.println("Couldnt start");
while (1);
Serial.println("MMA8451 found!");
mma.setRange(MMA8451_RANGE_2_G);
Serial.print("Range = "); Serial.print(2 << mma.getRange());
Serial.println("G");
// Read the 'raw' data in 14-bit counts
mma.read();
Serial.print("X:\t"); Serial.print(mma.x);
Serial.print("\tY:\t"); Serial.print(mma.y);
Serial.print("\tZ:\t"); Serial.print(mma.z);
Serial.println();
/* Get a new sensor event */
sensors_event_t event;
mma.getEvent(&event);
/* Display the results (acceleration is measured in m/s^2) */
Serial.print("X: \t"); Serial.print(event.acceleration.x); Serial.print("\t");
Serial.print("Y: \t"); Serial.print(event.acceleration.y); Serial.print("\t");
Serial.print("Z: \t"); Serial.print(event.acceleration.z); Serial.print("\t");
Serial.println("m/s^2 ");
/* Get the orientation of the sensor */
uint8_t o = mma.getOrientation();
switch (o) {
case MMA8451_PL_PUF:
Serial.println("Portrait Up Front");
break;
case MMA8451_PL_PUB:
Serial.println("Portrait Up Back");
break;
case MMA8451_PL_PDF:
Serial.println("Portrait Down Front");
break;
case MMA8451_PL_PDB:
Serial.println("Portrait Down Back");
break;
case MMA8451_PL_LRF:
Serial.println("Landscape Right Front");
break;
case MMA8451_PL_LRB:
Serial.println("Landscape Right Back");
break;
case MMA8451_PL_LLF:
Serial.println("Landscape Left Front");
break;
case MMA8451_PL_LLB:
Serial.println("Landscape Left Back");
break;
Serial.println();
delay(500);
