Step up3v3 to 5v
Step up3v3 to 5v
by r00n on Fri Dec 14, 2018 4:32 am
I am a learner, please be patient.
I am wanting to run 19 ws2812b leds from teensy 3.6 using the ws2812serial lib to get some visual feedback for an audio project.
I believe problems have arisen from different voltages of the 2 seperate systems so i am going to try to step up the voltage.
I have purchased a ic adafruit 74AHCT125 - Quad Level-Shifter (3V to 5V) - to do the job but I am failing to find a diagram of the required circuit to step up the volts. It's just the chip only, no shield.
Searching has unveiled a few circuit diagrams but I remain uncertain.
Would Yu please assist me to find a diagram that will show me how to integrate teensy, 74AHCT125, and ws2812 b leds?
r00n
Re: Step up3v3 to 5v
by adafruit_support_bill on Fri Dec 14, 2018 6:51 am
To start with, what will you be using to power the components in this system?
by r00n on Mon Dec 17, 2018 12:33 am
Teensy 3.6 is powered by USB but and runs at 3v3
The led chain is running of desktop power at 5v
Data line is 3.3 v
r00n
by adafruit_support_bill on Mon Dec 17, 2018 7:03 am
Do you have a signal ground between the processor and the first pixel? Some photos showing your wiring and connections would be helpful.
