NO GREEN LIGHT (16 x 12-bit PWM Servo Shield)
by PrestonAltree on Mon Dec 17, 2018 4:44 pm
Hi everybody,
I'm having an issue setting up my PWM board as a servo shield. The red light is illuminated and the reset button is responding, but despite having +5V DC running into the V+ terminal and ground running to the Gnd terminal, no green light. Any suggestions on how to fix?
EDIT: I should note that it's getting power through a 5V 1A voltage step down regulator from a 9V battery.
Thank you for your time,
Preston
PrestonAltree
Re: NO GREEN LIGHT (16 x 12-bit PWM Servo Shield)
by adafruit_support_bill on Mon Dec 17, 2018 5:23 pm
Please post some photos showing all your soldering and connections.
What kind of 9v battery? You will never get anything close to 1A from a garden-variety 9v 'transistor' battery.
by PrestonAltree on Mon Dec 17, 2018 5:34 pm
It's definitely a garden variety 9V battery. Am I not drawing enough amperage to power the board?
PrestonAltree
by adafruit_support_bill on Mon Dec 17, 2018 6:16 pm
The solder looks OK. A standard 9v battery is not going to power a servo very well - or for very long. But it should have enough power to light the LED.
Double check the polarity. And if you have a multimeter, measure the voltage at the screw-terminals.
by PrestonAltree on Mon Dec 17, 2018 7:18 pm
Interesting, it’s reading about 5.8v on the terminals but still no green LED. Polarity is correct, so I’m not sure what my problem is.
PrestonAltree
by adafruit_support_bill on Mon Dec 17, 2018 7:37 pm
There is a circle on the board labeled "C2". What is the voltage between the two pads inside that circle?
by PrestonAltree on Thu Dec 20, 2018 1:55 pm
Hey Bill,
According to my voltmeter, the voltage along those capacitor points is the same as the voltage coming into the circuit. I even swapped over to the recommenced 4 AA battery holder and I’m still not getting a green light.
PrestonAltree
by adafruit_support_bill on Thu Dec 20, 2018 2:07 pm
OK. That shows that power is getting through to the power rails, which means that the LED should have power too. That leads me to conclude that your board has a defective LED. It is probably functional otherwise. But if you contact support@adafruit.com with a link to this thread, we can send a replacement shield.
by PrestonAltree on Thu Dec 20, 2018 2:13 pm
Awesome! Thank you so much, Bill!
PrestonAltree
cron
