Newly-bought Leonardo no longer syncs/dls/connects
by mmgood on Fri Dec 28, 2018 1:42 am
First post. Apologies if this is less on-point than it should be, or redundant somehow (I did look on the Forums, but might have missed something).
I think my new Leonardo might be bricked, or close to it. I got it very recently, indirectly from Adafruit (via Amazon, at added cost *sigh*), after trying /three/ Inland (Micro Center) clones and finding all of them to have different bad header pins.
Anyway, it had been loading and running code just fine... and now it doesn't; the lights don't do the little happy dance, the IDE says it can't find the serial port, and when I hit reset on it, the L light blinks (throbs) 14 times and goes dark. Which is similar to what happens at an early part of a successful program load, except of course the "throbs" are far less numerous (about three).
A/B testing confirms that one of the Inland clones loads code OK with the same setup, so it doesn't seem to be a bad cable or PEBCAK.
The only suboptimal thing I can see I've done is use make/break of the micro-B connector as my power switch. Careful about static electricity, no weird loads or shorts or what-have-you.
I tossed the cute colorful box away, so probably can't return it to Amazon. Or can I?
I can limp along for now with the not-100%-working Inland clone but I'm wondering if (a) I might be able to throw myself on the mercy of Limor & Co and get a replacement from you guys (doubtful, but I'll ask), and (b) what the odds are that I might be able to use ICSP (I don't have the means this minute) and resurrect it?
Thanks very much for your great products!
mmgood
Re: Newly-bought Leonardo no longer syncs/dls/connects
by adafruit_support_bill on Fri Dec 28, 2018 7:48 am
I think my new Leonardo might be bricked, or close to it. I got it very recently, indirectly from Adafruit (via Amazon, . . .
We discontinued the Leonardo several years ago. You can try returning it via Amazon.
by mmgood on Fri Dec 28, 2018 3:00 pm
Thanks for the prompt reply.
mmgood
