Best approach to connect HC-SR04 Ultrasonic Sensor 20 ft fro
by spu3 on Thu Jan 03, 2019 9:10 am
I have a project that will require the connection of an HC-SR04 Ultrasonic Sonar Distance Sensor 20 ft. from my Arduino controller. Any suggestions on a reliable approach to make this connection? Thanks!
HC-SR04 Will be mounted on the rear bumper
spu3
Re: Best approach to connect HC-SR04 Ultrasonic Sensor 20 ft
by adafruit_support_bill on Thu Jan 03, 2019 9:32 am
I'd recommend shielded wire for a run that long in an automotive application. Automotive electrical systems tend to be quite noisy with inductive coils discharging through sparkplugs and all. 4-conductor microphone cable would be a good choice.
by spu3 on Thu Jan 03, 2019 10:17 am
adafruit_support_bill wrote:I'd recommend shielded wire for a run that long in an automotive application. Automotive electrical systems tend to be quite noisy with inductive coils discharging through sparkplugs and all. 4-conductor microphone cable would be a good choice.
Thank you Bill! Yes - the ignition system on my 'toy' is noisy. I'll give the mic cable a try. Would a shielded CAT-5 also be an option?
spu3
by adafruit_support_bill on Thu Jan 03, 2019 10:29 am
Yes. Shielded Cat-5 would be another good option.
