Neopixel Painter Arduino help
by unsogno on Fri Jan 04, 2019 1:50 pm
I'm using one of the examples from the Neopixel Painter library & need some help.
Currently, the code displays all colors/hues but I'd like to have it only display shades of green. Do I change the hue values so they are randomized between 100-140 for instance? Any guidance/suggestions would be helpful. Here is what I currently have:
int led = 6;           // the PWM pin the LED is attached to
#define NUMBEROFPIXELS 24 //Number of LEDs on the strip
#define PIXELPIN 6 //Pin where pixels are connected
#include "Arduino.h"
#include <NeoPixelPainter.h>
Adafruit_NeoPixel neopixels = Adafruit_NeoPixel(NUMBEROFPIXELS, PIXELPIN, NEO_GRB + NEO_KHZ800);
NeoPixelPainterCanvas pixelcanvas = NeoPixelPainterCanvas(&neopixels); //create canvas, linked to the neopixels (must be created before the brush)
NeoPixelPainterBrush pixelbrush = NeoPixelPainterBrush(&pixelcanvas); //crete brush, linked to the canvas to paint to
  pinMode(led, OUTPUT);
  while(true) //create a loop with an additional brush (is deleted automatically once the loop finishes)
    NeoPixelPainterBrush pixelbrush2 = NeoPixelPainterBrush(&pixelcanvas);
    if (pixelbrush2.isvalid() == false) Serial.println(F("brush2 allocation problem"));
    else  Serial.println(F("brush2 allocation ok"));
    static unsigned int hue = 0; //color hue to set to brush
    HSV brushcolor; //HSV color definition
      pixelbrush.setSpeed(300); //brush moving speed
      pixelbrush.setFadeSpeed(90);
      pixelbrush.setFadein(true); //brightness will fade-in if set to true
      pixelbrush.setFadeout(true);
      pixelbrush.setBounce(false);
    hue++;
    brushcolor.h = hue / 3; //divide by 3 to slow down color fading
    brushcolor.s = 255; //full saturation
    brushcolor.v = 255; //full brightness
    pixelbrush.setColor(brushcolor); //set new color to the bursh
    neopixels.clear();
    pixelbrush.paint(); //paint the brush to the canvas (and update the brush, i.e. move it a little)
    pixelcanvas.transfer(); //transfer (add) the canvas to the neopixels
    neopixels.show();
    break; //quit the while loop immediately (and delete the created brush)
Thank you.
unsogno
cron
