MAX31865
MAX31865
by Oriky on Sun Jan 06, 2019 10:00 am
I would like to use this module to work with 10K thermistor instead of PT100/PT1000. which modification its needs? which part in the code i should change to receive the temperature reading?
Oriky
Oriky
Re: MAX31865
by millercommamatt on Tue Jan 08, 2019 6:02 pm
It looks like the only difference between those parts is the reference resistor. You might be able to swap in an appropriate one for a PT10K probe which I guess would be a 43K 0.1% SMD resistor. It would probably be less hassle to just get a different probe.
millercommamatt
