Errors in BMP280 Library
by PhilCFG on Tue Jan 08, 2019 11:37 am
I have found two errors in the Adafruit library for the BMP280 on GitHub, Latest commit d20a271 on 8 Nov 2018
In BM280.h at line 256
return (t_sb << 5) | (filter << 3) | spi3w_en;
should be
return (t_sb << 5) | (filter << 2) | spi3w_en;
In BM280.h at line 272
return (osrs_t << 5) | (osrs_p << 3) | mode;
should be
return (osrs_t << 5) | (osrs_p << 2) | mode;
These errors caused incorrect configuration of the pressure oversampling and IIR filtering in the config and ctrl_meas registers. E.g. when setting pressure oversampling or IIR filter to x16 you get x2. I confirmed the wrong setting by viewing the I2C on a logic analyser and by noting that the raw pressure value returned was in increments of 8.
PhilCFG
