ItsyBitsy M0 Express compatible with Adafruit SleepyDog?
by rickpeterson on Wed Jan 09, 2019 6:33 pm
The GitHub page for Adafruit_SleepyDog library says it supports the Arduino Zero, Adafruit Feather M0 (ATSAMD21) hardware. Since IstyBitsy M0 Express uses the same ATSAMD21 MCU, it is compatible?
It also says:
Arduino Leonardo or other 32u4-based boards (e.g. Adafruit Feather) WITH CAVEAT: USB Serial connection is clobbered on sleep;
I experienced that problem with my Feather MO Express board which is not a 32u4 chip. Will I have this serial issue with the IstyBitsy M0 Express board?
I am ready to purchase two IstyBitsy M0 Express boards; but, want this feedback to avoid having to return them.
rickpeterson
Re: ItsyBitsy M0 Express compatible with Adafruit SleepyDog?
by adafruit_support_carter on Thu Jan 10, 2019 9:59 pm
I just ran the BasicUsage example on an Itsy M0 and it ran fine.
Adafruit Watchdog Library Demo!
Enabled the watchdog with max countdown of 4000 milliseconds!
Looping ten times while resetting the watchdog...
Loop #1
Loop #2
Loop #3
Loop #4
Loop #5
Loop #6
Loop #7
Loop #8
Loop #9
Loop #10
Get ready, the watchdog will reset in 4000 milliseconds!
After 4 secs, it reset and changed com ports (since Serial Monitor was still connected to this one). Opening Serial Monitor on the new com port started the above all over again.
by rickpeterson on Fri Jan 11, 2019 3:48 pm
I figured an M0 is an M0 regardless of the board it comes on; so, I ordered the two boards yesterday and they shipped today. Thank you for the confirmation. I have not had success with reopening Serial Monitor afterward [even with USBDevice.attach() command] testing with my current Feather M0 Express board; but, I can live with that annoyance.
I have been impressed with Adafruit's support and "reasonable" policies. Thank you for being there/here for your customers.
rickpeterson
by adafruit_support_carter on Fri Jan 11, 2019 9:27 pm
See if it changed ports after the reset. It did that to me.
