Undefined reference error Adafruit neopixel
by hellraise007 on Thu Jan 10, 2019 1:18 pm
Hello all,
First of all let me apologise if this is not the correct section to post this.
I'm using the Adafruit_NeoPixel arduino library in a project in Atmel Studio 7. While trying to buil the project I get this error
Severity   Code   Description   Project   File   Line
Error      undefined reference to `Adafruit_NeoPixel::Adafruit_NeoPixel(unsigned int, unsigned char, unsigned int)'   Touch   D:\touch-base\Main\Touch\light.h   11
Error      undefined reference to `Adafruit_NeoPixel::~Adafruit_NeoPixel()'   Touch   D:\touch-base\Main\Touch\light.h   11
Since I am fresh to Atmel Studio and the neopixel library, any help would be appreciated
#define LED_COUNT 8
#define LED_DRIVER_PIN 7
Adafruit_NeoPixel lights = Adafruit_NeoPixel(LED_COUNT, LED_DRIVER_PIN, NEO_RGB + NEO_KHZ800);
{Some code}
hellraise007
Re: Undefined reference error Adafruit neopixel
by oesterle on Thu Jan 10, 2019 3:39 pm
Hi, hellraise007!
As I understand it, Atmel Studio 7 can open Arduino sketches, and import libraries like Adafruit_NeoPixel. Apparently it looks for them in Arduino's libraries folder, which on Windows is in Documents > My Documents > Libraries.
Have you installed the Arduino IDE, and used that to install the Adafruit NeoPixel library? That's what I would try.
But there may be an easier way.
Cheers,
Eric
oesterle
by hellraise007 on Thu Jan 10, 2019 11:55 pm
oesterle wrote:Hi, hellraise007!
Cheers,
Eric
Hello Eric,
Yes I have imported the neopixel libraries from arduino into a separate project (I'm using to host just libraries and common code) in the same solution space. I have added the directories into the compiler options of the working project (which in turn solved another issue of not detecting the header file altogether). Still no outcome.
hellraise007
