Ultimate GPS Conflict
by adolfhack on Fri Jan 11, 2019 2:13 pm
Dear All,
is there a conflict between Ultimate GPS chip and HC-12 wireless module ?
im having troubles using the GPS when connecting HC-12
Thank you,
adolfhack
Re: Ultimate GPS Conflict
by franklin97355 on Fri Jan 11, 2019 4:23 pm
Can you post a link to the datasheet for your HC-12 module?
franklin97355
by adolfhack on Fri Jan 11, 2019 4:27 pm
adolfhack
by adolfhack on Fri Jan 11, 2019 4:44 pm
Here is a simple sketch im testing the modules on:
#include<SoftwareSerial.h>
String NMEA="";
char c;
int flag = 0;
String UPDATE_1_sec=  "$PMTK220,1000*1F\r\n";
String GPRMC_ONLY= "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29\r\n" ;//Send only the GPRMC Sentence
SoftwareSerial GPSSerial(3,2);
SoftwareSerial HC12(10, 11);
void setup()
  GPSSerial.begin(9600);
  delay(500);
  GPSSerial.print("$PMTK251,57600*2C"); // 57600 Baudrate
  GPSSerial.end();
  delay(500);
  GPSSerial.begin(57600);
  GPSSerial.print(UPDATE_1_sec);
  delay(500);
  GPSSerial.print(GPRMC_ONLY);
  delay(500);
  HC12.begin(9600);
  delay(500);
void loop()
readGPS();
if (flag==1)
  NMEA.trim();
  tone(7,1000,200);
  NMEA="";
  flag=0;
void readGPS(){
 if (GPSSerial.available()>0){
  c=GPSSerial.read();
  NMEA.concat(c);
  if(c=='\r')
   flag=1;
adolfhack
by franklin97355 on Fri Jan 11, 2019 5:15 pm
If you leave GPSserial at 9600 and the update rate default does it work?
franklin97355
by adolfhack on Fri Jan 11, 2019 5:19 pm
for a reason i dont know why, when i started HC-12 serial first then the gps it worked !
i mean i moved HC12.begin(9600) above and made GPSSerial.begin(9600) comes later it worked.
adolfhack
