Air Pressure Project
by acdavis1999 on Thu Jan 31, 2019 7:04 pm
Hi, I am working on a project and was curious if the Adafruit MPRLS Ported Pressure Sensor Breakout is capable of reading air pressure? I would like to work on a smaller project that needs an air pressure gauge and would like to use something like this so I can format more of the output.
acdavis1999
Re: Air Pressure Project
by franklin97355 on Thu Jan 31, 2019 7:40 pm
What PSI or pressure range do you need?
franklin97355
by acdavis1999 on Thu Jan 31, 2019 7:43 pm
Right now I'm looking in the range of 15 PSI - 20.
acdavis1999
by franklin97355 on Thu Jan 31, 2019 8:03 pm
Product says it can do 25PSI so it should be OK. The tutorial may help.
franklin97355
by acdavis1999 on Thu Jan 31, 2019 8:06 pm
So in this case any sensor (barometric) would work for measuring air pressure as long as it meets the psi range?
acdavis1999
