BLDC Motor; 24pulses/Revolution @ 8 poles.
by greenbarron64 on Thu Jan 31, 2019 8:39 pm
I've got two BLDC Motors, one is 8 poles and the other is 4 poles.
I need help reading the RPM using an Arduino UNO and printing to Serial.
I tired the code below gotten from; https://forum.arduino.cc/index.php?topic=455283.0 but it didn't work.
volatile long pulses = 0 ;  // must be volatile if used in ISR
void int_func ()
  pulses ++ ;
long get_pulsecount ()  // safely read pulses when its not changing
  noInterrupts () ;
  long res = pulses ;  // don't zero the count, just sample it, less scope for bugs (easy debug)
  interrupts () ;
  return res ;
void setup ()
  pinMode (2, INPUT_PULLUP) ; // just in case its open-collector
  attachInterrupt (0, int_func, RISING) ;  // interrupt channel 0 is pin 2 (for Uno etc)
unsigned long timestamp = 0L ;
long prev_pulses = 0L ;
void loop ()
  if (millis () - timestamp >= 1000)  // triggered every second
    timestamp += 1000 ;  // setup for next time
    long now_pulses = get_pulsecount () ;  // sample the count
    long count = now_pulses - prev_pulses ; // take difference from last sample
    prev_pulses = now_pulses ;  // update the previous value
    Serial.println (4 * count / 60.0) ;
Please help.
greenbarron64
Re: BLDC Motor; 24pulses/Revolution @ 8 poles.
by adafruit_support_bill on Fri Feb 01, 2019 7:00 am
. . . but it didn't work.
Can you be more specific?
How exactly did you have everything connected?
What exactly did it do or not do when you tried to run it?
