GFX library font with only numbers
by rvdokkum on Mon Feb 04, 2019 3:27 pm
Would it be possible to make a font file for the GFX library that only contains the number characters 0 to 9.
I like to create a 70 point font file with only 10 number characters to save memory.
http://oleddisplay.squix.ch/#/home
What are the rules when deleting characters not needed?
I like to use the font “Roboto mono”
Hope this is possible
Greets from Amsterdam / The Netherlands
Remko van Dokkum
rvdokkum
Re: GFX library font with only numbers
by jim_lee on Tue Feb 05, 2019 8:35 pm
Save the characters full size as a .bmp file. Put it on an SD drive and blit them to the screen as needed?
It's one way to approach the problem. You can do it using very little RAM as well.
-jim lee
jim_lee
by rvdokkum on Wed Feb 06, 2019 3:34 am
Hi Jim Lee
Thanks for your reply.
Using bitmaps would certainly be the best solution RAM wise.
I found my solution using the online font converter :
Erasing all characters not needed and leaving only the number characters using online font editor :
https://tchapi.github.io/Adafruit-GFX-Font-Customiser/
result :
https://www.youtube.com/watch?v=q7F2Pvf1IFY
Remko van Dokkum
rvdokkum
