Adafruit BMP085 library use questions
by William2015 on Sat Feb 09, 2019 6:24 pm
On a Trinket I'm using a tinyBMP085 modification of the Adafruit BMP085 library which is designed to be compatible with the Adafruit library. What's the required line of code to set the BMP085's oversampling/accuracy mode (ultra low power, standard, high resolution, ultra high resolution) from within a sketch?
Also, when for example this line of code is executed:
altitude = bmp.readAltitude();
is there a delay of a length depending upon the oversampling mode setting before a value is actually assigned to "altitude" and the sketch execution proceeds to the next line of code?
William2015
Re: Adafruit BMP085 library use questions
by William2015 on Sun Feb 10, 2019 2:59 pm
William2015 wrote:On a Trinket I'm using a tinyBMP085 modification of the Adafruit BMP085 library which is designed to be compatible with the Adafruit library. What's the required line of code to set the BMP085's oversampling/accuracy mode (ultra low power, standard, high resolution, ultra high resolution) from within a sketch?
Perhaps an answer to my first question - not within the sketch, but make this change within tinyBMP085.h to chose my desired STANDARD oversampling mode?:
class tinyBMP085 {
public:
tinyBMP085();
//uint8_t begin(uint8_t mode = BMP085_ULTRAHIGHRES); // by default go ULTRAHIRES mode
uint8_t begin(uint8_t mode = BMP085_STANDARD);
Yes. I found this in tinyBMP085.cpp:
else if (oversampling == BMP085_STANDARD)
_delay_ms(8);
William2015
by adafruit_support_carter on Sun Feb 10, 2019 3:19 pm
Looks like you figured it out. Mode is set when calling begin:
https://github.com/adafruit/Adafruit_BM ... 5_U.h#L104
