I've set up Arduinos and various Tiny variants, and never had so much trouble as with this Feather.
I have the nRF52840 BT Feather. I went through the Arduino and BSP setup exactly as described on the Adafruit web page.
The instructions say NOTHING about setting of the "Programmer:" entry on the tools menu. By trial and error I got it to work with "Bootloader DFU for Bluefruit nRF52". I this correct? (Strangely enough, it also works with the setting "AVRISP mkII" which I saw on some screencaps.)
So I can upload the blinker example and I can change timing and prove that I'm uploading it. The problem is it keeps repeating this error on startup and after every upload:
"Couldn't find a Board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload."
Why am I getting this? Have I set it up correctly, or not?
Regards,
John
- inspectorgadget
- inspectorgadget
Re: Couldn't find a Board on the selected port
This is what the output looks like when I build and upload:
Sketch uses 25236 bytes (3%) of program storage space. Maximum is 815104 bytes.
Global variables use 4672 bytes (1%) of dynamic memory, leaving 244160 bytes for local variables. Maximum is 248832 bytes.
Upgrading target on COM11 with DFU package C:\Users\jhaggis\AppData\Local\Temp\arduino_build_625977\sketch_feb12a.ino.zip. Flow control is disabled, Single bank, Touch disabled
Activating new firmware
Device programmed.
Device programmed.
- steime
I have the same problem.
Were you able to solve it?
I got this error message:
Arduino: 1.8.8 (Windows 10), Board: "Adafruit Bluefruit nRF52840 Feather Express, 0.2.6 (s140 6.1.1), Level 0 (Release)"
Sketch uses 25092 bytes (3%) of program storage space. Maximum is 815104 bytes.
Upgrading target on COM10 with DFU package C:\Users\stein\AppData\Local\Temp\arduino_build_401627\sketch_mar18a.ino.zip. Flow control is disabled, Single bank, Touch disabled
Device programmed.
Board at COM10 is not available
Device programmed.
- steime
This is the verbose error message during the upload:
Forcing reset using 1200bps open/close on port COM8
PORTS {COM8, } / {COM8, COM9, } => {COM9, }
Found upload port: COM9
C:\Users\stein\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\0.9.3/tools/adafruit-nrfutil/win32/adafruit-nrfutil.exe --verbose dfu serial -pkg C:\Users\stein\AppData\Local\Temp\arduino_build_401627/sketch_mar18a.ino.zip -p COM9 -b 115200 --singlebank
Upgrading target on COM9 with DFU package C:\Users\stein\AppData\Local\Temp\arduino_build_401627\sketch_mar18a.ino.zip. Flow control is disabled, Single bank, Touch disabled
Opened serial port COM9
Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 25540
Sending DFU start packet
Sending DFU init packet
Sending firmware file
Device programmed.
DFU upgrade took 2.218473434448242s
Device programmed.
- adafruit_support_carter
Can you check your version of the bootloader and update if necessary:
https://learn.adafruit.com/introducing- ... bootloader
- hathach
Make sure you download and install latedt adafruit driver as well.
