TCS34725
TCS34725
by geckco5621 on Thu Apr 04, 2019 4:00 pm
I recently purchased a TCS34725 and it does not respond.
when I run this code
#include <Wire.h>
#include <Adafruit_TCS34725.h>
/* Example code for the Adafruit TCS34725 breakout library */
/* Connect SCL    to analog 5
   Connect SDA    to analog 4
   Connect VDD    to 3.3V DC
   Connect GROUND to common ground */
/* Initialise with default values (int time = 2.4ms, gain = 1x) */
// Adafruit_TCS34725 tcs = Adafruit_TCS34725();
/* Initialise with specific int time and gain values */
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_700MS, TCS34725_GAIN_1X);
void setup(void) {
  Serial.begin(9600);
  if (tcs.begin()) {
    Serial.println("Found sensor");
  } else {
    Serial.println("No TCS34725 found ... check your connections");
    while (1);
  // Now we're ready to get readings!
void loop(void) {
  uint16_t r, g, b, c, colorTemp, lux;
  tcs.getRawData(&r, &g, &b, &c);
  colorTemp = tcs.calculateColorTemperature(r, g, b);
  lux = tcs.calculateLux(r, g, b);
  Serial.print("Color Temp: "); Serial.print(colorTemp, DEC); Serial.print(" K - ");
  Serial.print("Lux: "); Serial.print(lux, DEC); Serial.print(" - ");
  Serial.print("R: "); Serial.print(r, DEC); Serial.print(" ");
  Serial.print("G: "); Serial.print(g, DEC); Serial.print(" ");
  Serial.print("B: "); Serial.print(b, DEC); Serial.print(" ");
  Serial.print("C: "); Serial.print(c, DEC); Serial.print(" ");
  Serial.println(" ");
or any of the adafruit library example i just get this error "No TCS34725 found ... check your connections"
Any help would be appreciated. Thank You!
geckco5621
Re: TCS34725
by adafruit_support_bill on Thu Apr 04, 2019 4:41 pm
Please post some photos showing your soldering and connections to the board.
Re: TCS34725
by geckco5621 on Thu Apr 04, 2019 5:23 pm
I just got a new sensor and the issue was the sensor was broken
geckco5621
Re: TCS34725
by millercommamatt on Thu Apr 04, 2019 5:52 pm
They want to see the pictures so that they can rule out user error before they authorize a replacement.
millercommamatt
Re: TCS34725
by Akhilesh14 on Fri May 24, 2019 6:29 am
hi,
I am using tcs34725 color sensor for 1 week and I got results but I am in my final phase of my project and I am getting "check connections sensor not found". what should I do?
Akhilesh14
Re: TCS34725
by adafruit_support_bill on Fri May 24, 2019 7:02 am
@Akhilesh14 - Please do not double-post.
viewtopic.php?f=19&t=152139
