Control VESC with arduino
by pumpkinheadnick on Sat May 11, 2019 2:59 pm
Hello. I have ordered a VESC and have learned to communicate with it over UART. The issue is that I don't quite understand how to pull a specific member's value from a struct. I am using this library https://github.com/RollingGecko/VescUartControl/tree/VESC6.
This is the first time I have ever encountered a struct. If you look at their example code it serial prints the entire struct at once somehow. If you look into the local_datatypes file you can see the struct they reference.
I have read this https://forum.arduino.cc/index.php?topic=42681.0 which did not have too much info. Later I found this https://www.tutorialspoint.com/cprogramming/c_structures.htm which I thought was more useful.
After reading that I figured something like
Serial.println(measuredVal.rpm);
would work but it just returns 0.
Any ideas???
pumpkinheadnick
Re: Control VESC with arduino
by adafruit_support_bill on Sat May 11, 2019 6:33 pm
That is the way to access members of a struct. As for the content of that member, that is a question you should ask the author of the library.
by pumpkinheadnick on Sun May 12, 2019 12:33 am
Alright thanks for the confirmation. I will try to contact them, not sure what luck I will have.
pumpkinheadnick
