HELP! Adafruit 16-Channel 12-bit PWM/Servo Shield's v+ led i
by e_mergency on Mon May 13, 2019 9:09 am
I bought 'Adafruit 16-Channel 12-bit PWM/Servo Shield(https://learn.adafruit.com/adafruit-16- ... d/overview)' in this site(http://www.devicemart.co.kr/goods/view?no=1171141).
I carried out all the steps as described in the above site for the operation of the servo motor.
I used the example code provided by the library to operate the servo motor.
Below is the example code I used.
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// you can also call it with a different address and I2C interface
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(&Wire, 0x40);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
#define SERVOMIN  150 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX  600 // this is the 'maximum' pulse length count (out of 4096)
// our servo # counter
uint8_t servonum = 0;
  Serial.begin(9600);
  Serial.println("8 channel Servo test!");
  pwm.begin();
  pwm.setPWMFreq(60);  // Analog servos run at ~60 Hz updates
  delay(10);
// you can use this function if you'd like to set the pulse length in seconds
// e.g. setServoPulse(0, 0.001) is a ~1 millisecond pulse width. its not precise!
void setServoPulse(uint8_t n, double pulse) {
  double pulselength;
  pulselength = 1000000;   // 1,000,000 us per second
  pulselength /= 60;   // 60 Hz
  Serial.print(pulselength); Serial.println(" us per period");
  pulselength /= 4096;  // 12 bits of resolution
  Serial.print(pulselength); Serial.println(" us per bit");
  pulse *= 1000000;  // convert to us
  pulse /= pulselength;
  Serial.println(pulse);
  pwm.setPWM(n, 0, pulse);
  // Drive each servo one at a time
  Serial.println(servonum);
  for (uint16_t pulselen = SERVOMIN; pulselen < SERVOMAX; pulselen++) {
    pwm.setPWM(servonum, 0, pulselen);
  delay(500);
  for (uint16_t pulselen = SERVOMAX; pulselen > SERVOMIN; pulselen--) {
  delay(500);
  servonum ++;
  if (servonum > 7) servonum = 0;
The servo motor did not work even though the 1.5v * 4 power supply was connected to the shield.
In the meantime, I saw the video of the servo shield on YouTube, and the LED of v + next to VCC came in green. But my Servo Shield's V + led just kept on glowing red.
I am not good at English, but I would appreciate it if you could solve it well.
Thank you.,
e_mergency
Re: HELP! Adafruit 16-Channel 12-bit PWM/Servo Shield's v+ l
by adafruit_support_bill on Mon May 13, 2019 9:18 am
Try with just one servo connected. Your power supply may not have enough for 8 servos at the same time.
by e_mergency on Mon May 13, 2019 9:22 am
I've already tried it, but it's still not.
By the way, the V + led should be lit green, why is it red?
e_mergency
by e_mergency on Mon May 13, 2019 9:31 am
adafruit_support_bill wrote:Try with just one servo connected. Your power supply may not have enough for 8 servos at the same time.
As a result of my checking, it only runs up to Serial.println ("8 channel Servo test!") In void setup,
However, it has not been implemented since the pwm.begin () function.
e_mergency
by adafruit_support_bill on Mon May 13, 2019 10:58 am
Please post a clear photo of just the front of the shield with nothing connected.
by e_mergency on Mon May 13, 2019 6:50 pm
adafruit_support_bill wrote:Please post a clear photo of just the front of the shield with nothing connected.
Here. Thank you for helping.
e_mergency
by adafruit_support_bill on Mon May 13, 2019 7:04 pm
That is not one of our shields. Looks like a generic copy. They may have just used different components.
by e_mergency on Mon May 13, 2019 7:20 pm
adafruit_support_bill wrote:That is not one of our shields. Looks like a generic copy. They may have just used different components.
Thank you for reply. I'll try to get another product again.
e_mergency
cron
