Q. about Adafruit's Microbit to Arduino IDE Library
by Blueshark on Sat May 18, 2019 6:58 am
I just got my Microbit, it works easy, even with Neopixels in the Makecode program.
Microbit
https://www.adafruit.com/product/3362
and Accesory
https://www.adafruit.com/product/3695
Q. Do I have to "Re-flash" my Microbit with a special program to get it to work back again with its hex files, after using the Adafruit Microbit to Arduino IDE Library: kinda like what you have to do with Circuit Playground Express when going back and forth between Arduino IDE and Circuit Python or Makecode?
I just dont want use Arduino in Microbit right now if you have to re-flash Microbit back with a special program if you use it with the Arduino IDE.
Cheers.
Blueshark
Re: Q. about Adafruit's Microbit to Arduino IDE Library
by Blueshark on Sun May 19, 2019 2:18 am
After testing the Adafruit Library for the Microbit for the Arduino IDE, its safe to say you don't need to re-flash some special software to get it to read your native hex files for the Microbit.
Just forllow the Tutorial here
https://learn.adafruit.com/use-micro-bit-with-arduino
you will also need this Library to make the examples work; tutorial does not provide link.
https://github.com/sandeepmistry/arduino-BLEPeripheral
thats it, you can go back and forth Arduino IDE and regular Microbit Hex files with no problem just copy them to your Microbit.
Cheers...
Blueshark
