Adafruit Breakout Board SPI Error After Soldering
Sa5jared
Post by Sa5jared »
I am working on a project with the Adafruit microSD breakout board. I am using the board with an Arduino Nano and an ArduCAM mini camera. When the circuit was setup on a breadboard it worked well. But when I soldered wire connections between the 3 I am getting SPI errors. For the microSD board I am getting that there is an SD card error. These issues only arose after I soldered everything together. And yes I've checked all solder joints and that I've made the correct connections.
Any ideas as to why I'm getting these errors?
adafruit_support_carter
Re: Adafruit Breakout Board SPI Error After Soldering
Post a photo of your setup showing how everything is connected.
Return to “Arduino”
