I'm currently working on an 14x14 interactive LED table for an university assignment. Therefore I use 14 SK6812 strips each being 14 NeoPixels long. Each strip is run on a separate pin of an Arduino Mega 2560. To get the information which LEDs should be set to which color I pass an int[14][14][3] JSON object as a string, deserialize it and get the RGB values from it to set the color. This works fine as long as I only control 7 LED strips in my code. However if there are more than 7 strips accessed at any point in the code it appears that the JSON object can't be read (at least the arduino prints only 0 to the console when reading from the deserialized object).
There is no problem with serial communication as I can perfectly read and process the JSON object when not using more than 7 strips. My code at the moment looks like this:
#include <ArduinoJson.h>
#ifdef __AVR__
#include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
#define PINROW0 2
#define PINROW1 3
#define PINROW2 4
#define PINROW3 5
#define PINROW4 6
#define PINROW5 7
#define PINROW6 8
#define PINROW7 22
#define PINROW8 24
#define PINROW9 26
#define PINROW10 28
#define PINROW11 30
#define PINROW12 32
#define PINROW13 34
#define NUMPIXELS 14 //Anzahl der Pixel pro Reihe
/*Adafruit_NeoPixel row0 = Adafruit_NeoPixel(NUMPIXELS, PINROW0, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row1 = Adafruit_NeoPixel(NUMPIXELS, PINROW1, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row2 = Adafruit_NeoPixel(NUMPIXELS, PINROW2, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row3 = Adafruit_NeoPixel(NUMPIXELS, PINROW3, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row4 = Adafruit_NeoPixel(NUMPIXELS, PINROW4, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row5 = Adafruit_NeoPixel(NUMPIXELS, PINROW5, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row6 = Adafruit_NeoPixel(NUMPIXELS, PINROW6, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row7 = Adafruit_NeoPixel(NUMPIXELS, PINROW7, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row8 = Adafruit_NeoPixel(NUMPIXELS, PINROW8, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row9 = Adafruit_NeoPixel(NUMPIXELS, PINROW9, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row10 = Adafruit_NeoPixel(NUMPIXELS, PINROW10, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row11 = Adafruit_NeoPixel(NUMPIXELS, PINROW11, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row12 = Adafruit_NeoPixel(NUMPIXELS, PINROW12, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row13 = Adafruit_NeoPixel(NUMPIXELS, PINROW13, NEO_GRB + NEO_KHZ800);
//Adafruit_NeoPixel currentStrip = Adafruit_NeoPixel(NUMPIXELS, pins[0], NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel row[] = { //Initialisieren des Arrays, das die addressierbaren LED Streifen im Adafruit Format enthält
Adafruit_NeoPixel(NUMPIXELS, PINROW0, NEO_GRB + NEO_KHZ800),
Adafruit_NeoPixel(NUMPIXELS, PINROW1, NEO_GRB + NEO_KHZ800),
Adafruit_NeoPixel(NUMPIXELS, PINROW2, NEO_GRB + NEO_KHZ800),
Adafruit_NeoPixel(NUMPIXELS, PINROW3, NEO_GRB + NEO_KHZ800),
Adafruit_NeoPixel(NUMPIXELS, PINROW4, NEO_GRB + NEO_KHZ800),
Adafruit_NeoPixel(NUMPIXELS, PINROW5, NEO_GRB + NEO_KHZ800),
Adafruit_NeoPixel(NUMPIXELS, PINROW6, NEO_GRB + NEO_KHZ800)/*,
Adafruit_NeoPixel(NUMPIXELS, PINROW7, NEO_GRB + NEO_KHZ800),
Adafruit_NeoPixel(NUMPIXELS, PINROW8, NEO_GRB + NEO_KHZ800),
Adafruit_NeoPixel(NUMPIXELS, PINROW9, NEO_GRB + NEO_KHZ800),
Adafruit_NeoPixel(NUMPIXELS, PINROW10, NEO_GRB + NEO_KHZ800),
Adafruit_NeoPixel(NUMPIXELS, PINROW11, NEO_GRB + NEO_KHZ800),
Adafruit_NeoPixel(NUMPIXELS, PINROW12, NEO_GRB + NEO_KHZ800),
Adafruit_NeoPixel(NUMPIXELS, PINROW13, NEO_GRB + NEO_KHZ800)*/
#define DELAY 1000 //Refresh Zyklus auf 10 Millisekunden setzen
#define NUMSTRIPS 7/*(sizeof(row)/sizeof(row[0]))*/ //Anzahl der verbundenen LED Streifen definieren
int values[14][14][3];
String matrixAsString = "";
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
clock_prescale_set(clock_div_1);
#endif
/*Seriellen Port über den der Pi sich mit dem Arduino verbindet einrichten*/
Serial.begin(115200); //setzen der Bitrate auf 115200 Bit pro Sekunde
Serial.setTimeout(100000);
/*NeoPixel Library initialisieren*/
for (int i = 0; i < NUMSTRIPS; i++) {
row[i].begin();
row[i].show();
void process(String matrixAsString) {
DynamicJsonDocument doc(4372);
Serial.println(matrixAsString);
deserializeJson(doc, matrixAsString);
Serial.println((int)(doc[2][10][0]));
Serial.println((int)(doc[5][10][0]));
Serial.println((int)(doc[0][1][2]));
Serial.println((int)(doc[0][0][1]));
for (int j = 0; j < NUMPIXELS; j++) {
for (int k = 0; k < 3; k++) {
values[i][j][k] = (int)(doc[i][j][k]);
void paint() {
int r = 0;
int g = 0;
int b = 0;
r = values[i][j][0];
g = values[i][j][1];
b = values[i][j][2];
row[i].setPixelColor(j, row[i].Color(r, g, b));
row[i].show();
//infinite loop refreshing the matrix
while (Serial.available()) {
char c = Serial.read();
matrixAsString += c;
if (c == '\n') {
process(matrixAsString);
paint();
The LEDs get their power by a separate PC power supply unit attached to the table so an inappropriate amount of power supply doesn't seem to be a problem here. Also trying to run the code on 2 Arduino Duemilanove and assigning 7 strips to each of them didn't solve the problem.
Sidenote:
The behaviour described above is based on the results I got from testing tonight. However after I just tested my code somehow I'm now only able to address 3 LED strips at once. If I try to use more than 3 strips now the application prints 0 to the console instead of the correct values.
Thanks in advance for your time and your help. I really appreciate any possible tips.For testing consider using this data which is a correct representation of an int[7][14][3]:
[[[0,0,0],[253,47,14],[247,255,158],[102,27,49],[174,28,214],[152,94,233],[88,191,33],[98,155,212],[236,248,0],[0,225,48],[130,88,246],[110,85,156],[240,100,157],[50,247,165]],[[58,173,117],[94,72,171],[88,58,115],[145,216,137],[86,6,132],[183,76,142],[161,10,135],[158,84,240],[250,29,67],[73,44,83],[9,131,139],[254,243,6],[10,104,226],[16,168,56]],[[32,181,156],[233,3,126],[7,47,165],[76,201,169],[19,86,14],[254,20,62],[17,217,245],[186,153,182],[137,134,242],[222,81,181],[206,36,102],[46,204,39],[9,51,142],[200,1,125]],[[22,118,77],[74,127,167],[118,232,100],[223,224,2],[189,173,115],[229,64,94],[38,194,34],[46,69,126],[109,220,207],[165,145,190],[54,171,139],[52,177,94],[168,172,195],[108,164,177]],[[36,237,198],[164,171,19],[156,127,173],[40,126,252],[131,99,227],[160,249,39],[117,100,94],[172,27,76],[111,204,150],[176,185,191],[170,83,126],[147,148,6],[231,214,27],[195,106,166]],[[69,79,30],[166,125,92],[52,131,50],[142,231,212],[118,109,33],[238,141,107],[22,140,165],[45,59,189],[73,49,251],[228,214,179],[168,159,210],[161,76,22],[255,99,143],[232,250,151]],[[92,251,102],[138,149,24],[29,122,180],[46,66,226],[188,114,201],[42,204,18],[197,43,53],[209,158,67],[146,114,102],[84,217,136],[135,135,208],[145,147,208],[64,14,151],[29,97,2]]]
Or this for an int[14][14][3]:
[[[0,0,0],[173,204,86],[4,136,15],[210,234,185],[86,9,54],[231,81,107],[102,28,127],[181,161,131],[75,190,182],[176,246,35],[12,178,20],[200,91,70],[208,96,182],[156,150,86]],[[212,236,18],[67,253,232],[37,49,223],[227,138,158],[30,29,243],[56,230,99],[15,111,103],[176,176,161],[13,20,232],[132,216,93],[212,212,208],[205,217,3],[42,63,83],[132,182,107]],[[108,116,229],[2,3,98],[233,132,104],[183,227,245],[23,32,226],[113,97,101],[47,34,97],[219,201,42],[5,63,252],[9,249,182],[203,178,90],[126,222,26],[140,134,6],[202,85,250]],[[142,119,65],[27,181,99],[116,81,226],[37,1,26],[25,88,188],[112,242,9],[225,228,163],[9,2,224],[127,180,84],[90,62,190],[16,82,239],[250,159,55],[245,70,141],[81,252,140]],[[60,38,22],[225,34,72],[74,90,158],[160,236,178],[89,54,12],[11,192,248],[180,195,62],[210,138,17],[38,224,3],[220,129,220],[74,70,18],[134,127,167],[8,77,16],[142,160,27]],[[127,71,211],[27,78,154],[166,30,142],[49,244,145],[26,189,67],[180,21,74],[244,21,110],[98,101,192],[235,1,26],[53,67,157],[20,26,118],[170,73,182],[18,154,251],[228,120,241]],[[140,42,110],[125,191,106],[165,29,105],[224,83,119],[92,46,196],[103,26,200],[82,41,192],[247,253,74],[145,195,66],[125,199,51],[98,36,102],[177,219,46],[100,153,25],[243,188,135]],[[140,28,15],[235,44,155],[214,83,18],[1,43,183],[133,170,72],[13,23,127],[136,216,206],[255,239,79],[109,84,23],[119,156,220],[178,35,233],[194,236,66],[251,197,69],[193,186,49]],[[95,240,243],[157,204,249],[78,172,86],[210,178,191],[124,121,252],[136,176,142],[50,134,253],[252,22,163],[91,19,15],[154,140,41],[70,105,162],[17,237,6],[214,172,31],[16,191,61]],[[240,236,220],[107,214,220],[165,220,180],[218,152,62],[191,95,42],[120,55,76],[140,196,93],[200,72,78],[11,131,75],[128,245,97],[70,11,111],[154,220,99],[202,71,49],[164,64,201]],[[19,11,70],[95,125,78],[181,255,229],[42,107,80],[225,59,98],[233,53,76],[81,183,2],[59,117,169],[94,22,190],[85,128,144],[44,4,31],[180,176,34],[86,200,52],[84,120,146]],[[43,126,132],[244,84,69],[9,7,243],[10,102,149],[109,84,119],[68,160,76],[57,142,178],[156,106,136],[55,120,232],[103,188,135],[60,13,16],[112,69,168],[89,147,232],[125,35,131]],[[131,32,3],[84,68,20],[120,223,143],[66,35,29],[28,174,120],[7,212,251],[167,90,253],[161,221,150],[148,196,229],[14,227,89],[212,31,219],[191,160,42],[210,190,152],[75,109,138]],[[22,235,71],[221,130,169],[53,98,215],[245,138,147],[172,227,198],[197,76,30],[64,136,166],[36,31,172],[140,95,30],[117,245,78],[5,32,11],[61,121,19],[243,13,240],[72,28,77]]]
