📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
16x32 Matrix P10(1R)-V706A with RGB Matrix Bonnet
by seloca on Tue Jul 16, 2019 9:02 am
Hello everyone, I have a problem. I'm trying for weeks to connect the 16x32 panel with the Raspberry Pi 3 Model 3. I recently bought the RGB Matrix Bonnet. However, I do not come first. How should the pin laying in the Pi or RGB matrix and how can I control it. Is there no script for this?
In the appendix I have the model name of the panel and the pin assignment.
I need a guide to it.
Thank you very much for your help!
Panel pin laying
Model name P10(1R)-V706A
seloca
Re: 16x32 Matrix P10(1R)-V706A with RGB Matrix Bonnet
by adafruit_support_carter on Wed Jul 17, 2019 4:08 pm
There's a guide for the RGB Matrix Bonnet here:
https://learn.adafruit.com/adafruit-rgb ... i/overview
by seloca on Thu Jul 18, 2019 6:19 am
strangely, it does not work with the P10 (1R) -V706A. how must the pin laying be that or is it simply enough to connect the IDC plug with the bonnet and matrix. It does not work with the IDC. I assume that the pin laying is not the same. Can you help me?
seloca
by adafruit_support_carter on Thu Jul 18, 2019 12:52 pm
Not all RGB matrices are the same. We only support usage with the ones in our shop:
https://www.adafruit.com/categories/327
which we've tested with.
by seloca on Fri Jul 19, 2019 2:47 am
could you help me with how to move the pins from bonnet to the matrix (see photo)?
seloca
by adafruit_support_carter on Fri Jul 19, 2019 12:08 pm
Sorry, I can't. We don't know anything about that matrix. You'll have to see if you can figure out the pinouts for your matrix and hopefully match it to what's shown in the guide linked.
by seloca on Mon Jul 22, 2019 7:05 am
I really come first. Main problem is the pin laying. On the screenshot I uploaded below are the names for the pins on the matrix, but which one do I have to plug into which pin in the bonnet. What else do I need to adjust?
seloca
by adafruit_support_carter on Mon Jul 22, 2019 12:13 pm
We have no experience with that matrix and do not know how it should be connected or if it's even compatible.
by seloca on Tue Jul 23, 2019 3:22 am
OE CLK A, B, C, D, LAT B1, B2. What funtions does it have?
seloca
by seloca on Tue Jul 30, 2019 7:28 am
I ordered this here and now wanted to connect with the RGB matrix bonnet with this matrix LED panel. Is there a guide and I want to control the Pannel via a web interface, is there a solution?
https://www.adafruit.com/product/420
seloca
by adafruit_support_carter on Tue Jul 30, 2019 11:22 am
The main guide is here:
Web control could be done numerous ways. Looks like there's at least one guide here:
https://learn.adafruit.com/raspberry-pi ... rix-webapp
with an approach.
by seloca on Tue Aug 06, 2019 3:33 am
https://learn.adafruit.com/raspberry-pi ... pplication
webapp does not work do you have an alternative.
seloca
by adafruit_support_carter on Tue Aug 06, 2019 10:42 am
If the guide doesn't work we can update it. What problem did you run into?
I'd take a look at using something like Flask, which is a Python web framework.
by seloca on Thu Aug 08, 2019 9:52 am
I have 5 matrix wall and 5 raspberry pi. How can I change as mutlicast, if I want to send a text to all 5 Raspberry pi in the script (rpi-rgb-led-matrix-webapp-0.0.1-SNAPSHOT.war)?
I would like to have in the header text z.b a button where the 5 Raspberry pi stand and I can choose individually or as a broadcast to send all the text
seloca
by seloca on Fri Aug 09, 2019 8:49 am
webapp: still images and scrolling text does not happen. it does not work. Animations does work but he other function doesnt work. Can you help me?
seloca
