Adafruit ULTIMAGE gps AND LoRa radio 433MHz
quentinGik
Post by quentinGik »
Hello all, I'm working on an arduino project that uses several modules including the LoRa grove radio 433MHz (from seeedstudio) and the Ultimate gps Adafruit.
The fact is that these 2 modules communicate with my microcontroller (Mega2560 PRO (embed) CH-340G / ATmega2560-16AU from RobotDyn) on serial ports.
Ultimate gps : 10-9 RX TX
LoRa: 13-14 RX TX
What happens is that the last of the 2 modules I initialized in my Setup will work in the rest of the code, but not the first module.
I did several tests to identify the problem and i'm sure it comes from that.
For example if I initiate the GPS before the Lora, the Lora will work but the gps and vice versa.
I think I should use the.listen() function, but being a young arduino amateur I don't yet know how to use this function correctly.
Help wouldn't be a refusal.
Here is my code: (Gps init first before LoRa, gps not working. If i do the opposite init, Gps work)
#include <BlockDriver.h>
#include <FreeStack.h>
#include <MinimumSerial.h>
#include <SdFat.h>
#include <SdFatConfig.h>
#include <sdios.h>
#include <SysCall.h>
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
#include <RH_RF95.h>
#include <Adafruit_INA260.h>
Adafruit_INA260 ina260 = Adafruit_INA260();
Adafruit_INA260 ina260B = Adafruit_INA260();
SdFat SD;
const int chipSelect = 53;
SoftwareSerial mySerial(10, 9);
Adafruit_GPS GPS(&mySerial);
#define GPSECHO  true
#ifdef __AVR__
SoftwareSerial SSerial(13,14); // RX, TX
#define COMSerial SSerial
#define ShowSerial Serial
RH_RF95<SoftwareSerial> rf95(COMSerial);
#endif
#ifdef ARDUINO_SAMD_VARIANT_COMPLIANCE
#define COMSerial Serial1
#define ShowSerial SerialUSB
RH_RF95<Uart> rf95(COMSerial);
#endif
#ifdef ARDUINO_ARCH_STM32F4
RH_RF95<HardwareSerial> rf95(COMSerial);
#endif
struct datax{
  unsigned long ms;
  float cur_A;
  float power_A;
  float voltage_A;
  float energy_A;
  float cur_B;
  float power_B;
  float voltage_B;
  float energy_B;
  int annee;
  int mois;
  int jours;
  int heure;
  int minuts;
  int sec;
  int latitude;
  float lat;
  int longitude;
  float longe;
  int altitudz;
  //float windspeed;
}datasend;
float cur_A = 0;
float powe_A = 0;
float volt_A = 0;
float energy_A = 0;
float cur_B = 0;
float powe_B = 0;
float volt_B = 0;
float energy_B = 0;
//        TEMPS
unsigned long previousMillis = 0;
unsigned long interval = 1000;
unsigned long currentMillis;
  Serial.begin(115200);
  delay(5000);
  GPS.begin(9600);
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
  GPS.sendCommand(PGCMD_ANTENNA);
  if (!ina260.begin(0x40)) {
    Serial.println(F("Couldn't find INA260 chip"));
    while (1);
  if (!ina260B.begin(0x41)) {
    Serial.println(F("Couldn't find INA260B chip"));
    while (1);
  if (!SD.begin(chipSelect)){
    Serial.println(F("Couldn't find SD chip"));
    while (1);
  if (!rf95.init()){
    Serial.println(F("Couldn't find LoRa chip"));
    while(1);
  rf95.setTxPower(20, false);
  rf95.setFrequency(434.0);
  Serial.println(F("Found INA260-INA260B-SD-LoRa chips"));
  File DataFile = SD.open("datalog.txt",FILE_WRITE);
  if (DataFile){
    DataFile.println(F("Found INA260-INA260B-SD-LoRa chips")); //1
    DataFile.print(F("CurrentA_mA;"));                    //2
    DataFile.print(F("CurrentB_mA;"));                    //3
    DataFile.print(F("busVoltageA_mV;"));                 //4
    DataFile.print(F("busVoltageB_mV;"));                 //5
    DataFile.print(F("PowerA_mW;"));                      //6
    DataFile.print(F("PowerB_mW;"));                      //7
    DataFile.print(F("EnergyA_mWH;"));                    //8
    DataFile.print(F("EnergyB_mWH;"));                    //9
    DataFile.print(F("Temps_mS;"));                       //10
    DataFile.print(F("Heure;"));                          //11
    DataFile.print(F("Date;"));                           //12
    DataFile.print(F("FIX;"));                            //13
    DataFile.print(F("Latitude;"));                       //14
    DataFile.print(F("Longitude;"));                      //15
    DataFile.print(F("Altitude;"));                       //16
    DataFile.println(F("XXX;"));                          //17
    DataFile.close();
  char c = GPS.read();
  // if you want to debug, this is a good time to do it!
  if ((c) && (GPSECHO))
  Serial.write(c);
  currentMillis = millis();
  if (currentMillis - previousMillis >=interval){
    previousMillis = currentMillis;
    if (GPS.newNMEAreceived()) {
      if (!GPS.parse(GPS.lastNMEA()))   // this also sets the newNMEAreceived() flag to false
      return;  // we can fail to parse a sentence in which case we should just wait for another
    Serial.print(F("\nTime: "));
    if (GPS.hour < 10) { Serial.print('0'); }
    Serial.print(GPS.hour, DEC); Serial.print(':');
    if (GPS.minute < 10) { Serial.print('0'); }
    Serial.print(GPS.minute, DEC); Serial.print(':');
    if (GPS.seconds < 10) { Serial.print('0'); }
    Serial.print(GPS.seconds, DEC); Serial.print('.');
    if (GPS.milliseconds < 10) {
      Serial.print(F("00"));
    else if (GPS.milliseconds > 9 && GPS.milliseconds < 100) {
      Serial.print("0");
    Serial.println(GPS.milliseconds);
    Serial.print(F("Date: "));
    Serial.print(GPS.day, DEC); Serial.print('/');
    Serial.print(GPS.month, DEC); Serial.print(F("/20"));
    Serial.println(GPS.year, DEC);
    Serial.print(F("Fix: ")); Serial.print((int)GPS.fix);
    Serial.print(F(" quality: ")); Serial.println((int)GPS.fixquality);
    if (GPS.fix) {
      Serial.print(F("Location: "));
      Serial.print(GPS.latitude, 4); Serial.print(GPS.lat);
      Serial.print(F(", "));
      Serial.print(GPS.longitude, 4); Serial.println(GPS.lon);
      Serial.print(F("Speed (knots): ")); Serial.println(GPS.speed);
      Serial.print(F("Angle: ")); Serial.println(GPS.angle);
      Serial.print(F("Altitude: ")); Serial.println(GPS.altitude);
      Serial.print(F("Satellites: ")); Serial.println((int)GPS.satellites);
    Serial.println();
    cur_A = ina260.readCurrent();
    powe_A = ina260.readPower();
    volt_A = ina260.readBusVoltage();
    energy_A = powe_A/3600.0 + energy_A;
    cur_B = ina260B.readCurrent();
    powe_B = ina260B.readPower();
    volt_B = ina260B.readBusVoltage();
    energy_B = powe_B/3600.0 + energy_B;
    datasend.ms = currentMillis;
    datasend.cur_A = cur_A;
    datasend.power_A = powe_A;
    datasend.voltage_A = volt_A;
    datasend.energy_A = energy_A;
    datasend.cur_B = cur_B;
    datasend.power_B = powe_B;
    datasend.voltage_B = volt_B;
    datasend.energy_B = energy_B;
    datasend.annee = (GPS.year);
    datasend.mois = (GPS.month);
    datasend.jours = (GPS.day);
    datasend.heure = (GPS.hour);
    datasend.minuts = (GPS.minute);
    datasend.sec = (GPS.seconds);
    datasend.latitude = (GPS.latitude, 4);
    datasend.lat = (GPS.lat);
    datasend.longitude = (GPS.longitude, 4);
    datasend.longe = (GPS.lon);
    datasend.altitudz = (GPS.altitude);
    //datasend.windspeed = windSpeed;
    rf95.send((uint8_t*)&datasend,sizeof(datasend));
    rf95.waitPacketSent();
    Serial.print(F("Current: "));
    Serial.print(cur_A);
    Serial.print(F("   "));
    Serial.print(cur_B);
    Serial.println(F(" mA"));
    Serial.print(F("Bus Voltage: "));
    Serial.print(volt_A);
    Serial.print(volt_B);
    Serial.println(F(" mV"));
    Serial.print(F("Power: "));
    Serial.print(powe_A);
    Serial.print(powe_B);
    Serial.println(F(" mW"));
    Serial.print(F("Energy: "));
    Serial.print(energy_A);
    Serial.print(energy_B);
    if (DataFile){
      DataFile.print(cur_A);              //2
      DataFile.print(F(";"));
      DataFile.print(cur_B);              //3
      DataFile.print(volt_A);             //4
      DataFile.print(volt_B);             //5
      DataFile.print(powe_A);             //6
      DataFile.print(powe_B);             //7
      DataFile.print(energy_A);           //8
      DataFile.print(energy_B);           //9
      DataFile.print(currentMillis);                  //10
      DataFile.print(GPS.hour, DEC);                  //11
      DataFile.print(F(":"));
      DataFile.print(GPS.minute, DEC);                //11
      DataFile.print(GPS.seconds, DEC);               //11
      DataFile.print(GPS.day, DEC);                   //12
      DataFile.print(F("/"));
      DataFile.print(GPS.month, DEC);                 //12
      DataFile.print(GPS.year, DEC);                  //12
      DataFile.print((int)GPS.fix);                   //13
      DataFile.print(GPS.latitude, 4); DataFile.print(GPS.lat);  //14
      DataFile.print(GPS.longitude, 4); DataFile.print(GPS.lon); //15
      DataFile.print(GPS.altitude);                   //16
      DataFile.println(F(";"));
      DataFile.close();
quentinGik
Re: Adafruit ULTIMAGE gps AND LoRa radio 433MHz
Ok, just used Hardwareserial of the GPs and it works, thanks anyway :)
Return to “Arduino”
