multi rfid reader sketch issue
by chrisnet on Sun Jul 28, 2019 4:37 pm
I have in issue with the sketch not working the way I think it should!
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_PN532.h>
// If using the breakout with SPI, define the pins for SPI communication.
#define PN532_SCK  (2)
#define PN532_MOSI (3)
#define PN532_SS   (4)
#define PN532_MISO (5)
#define PN532_SS2   (6)
// If using the breakout or shield with I2C, define just the pins connected
// to the IRQ and reset lines.  Use the values below (2, 3) for the shield!
#define PN532_IRQ   (2)
#define PN532_RESET (3)  // Not connected by default on the NFC Shield
// Uncomment just _one_ line below depending on how your breakout or shield
// is connected to the Arduino:
// Use this line for a breakout with a SPI connection:
Adafruit_PN532 nfc(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS);
Adafruit_PN532 nfc2(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS2);
// Use this line for a breakout with a hardware SPI connection.  Note that
// the PN532 SCK, MOSI, and MISO pins need to be connected to the Arduino's
// hardware SPI SCK, MOSI, and MISO pins.  On an Arduino Uno these are
// SCK = 13, MOSI = 11, MISO = 12.  The SS line can be any digital IO pin.
//Adafruit_PN532 nfc(PN532_SS);
// Or use this line for a breakout or shield with an I2C connection:
//Adafruit_PN532 nfc(PN532_IRQ, PN532_RESET);
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
// also change #define in Adafruit_PN532.cpp library file
//   #define Serial SerialUSB
#endif
void setup(void) {
  Serial.begin(115200);
  Serial.println("Hello!");
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.println("Didn't find PN53x board 1");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
    // configure board to read RFID tags
  nfc.SAMConfig();
  delay(1000);
  nfc2.begin();
  uint32_t versiondata2 = nfc2.getFirmwareVersion();
  if (! versiondata2) {
    Serial.println("Didn't find PN53x board 2");
    while (1); // halt
  Serial.print("Found chip PN5"); Serial.println((versiondata2>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata2>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata2>>8) & 0xFF, DEC);
  nfc2.SAMConfig();
  Serial.println("Waiting for an ISO14443A Card ...");
void loop(void) {
  ReadRFID1();
  ReadRFID2();
void ReadRFID1(){
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  if (success) {
    // Display some basic information about the card
    Serial.println("Found an ISO14443A card");
    Serial.print("  UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
    Serial.print("  UID Value: ");
    nfc.PrintHex(uid, uidLength);
    if (uidLength == 4)
      // We probably have a Mifare Classic card ...
      uint32_t cardid = uid[0];
      cardid <<= 8;
      cardid |= uid[1];
      cardid <<= 8;
      cardid |= uid[2];
      cardid <<= 8;
      cardid |= uid[3];
      Serial.print("Seems to be a Mifare Classic card #");
      Serial.println(cardid);
    Serial.println("");
  else{
     Serial.println("No card at reader 1");
void ReadRFID2(){
  //// Look at second reader
  uint8_t uid2[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength2;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  uint8_t success2;
  success2 = nfc2.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid2, &uidLength2);
  if (success2) {
    Serial.print("  UID Length: ");Serial.print(uidLength2, DEC);Serial.println(" bytes");
    nfc2.PrintHex(uid2, uidLength2);
    if (uidLength2 == 4)
      uint32_t cardid = uid2[0];
      cardid <<= 8;
      cardid |= uid2[1];
      cardid <<= 8;
      cardid |= uid2[2];
      cardid <<= 8;
      cardid |= uid2[3];
    Serial.println("");
  else{
    Serial.println("No card at 2nd reader");
IF
  ReadRFID1();
  ReadRFID2();
Then it will read the tag if at ReadRFID1 but not ReadRFID2
IF
  ReadRFID2();
  ReadRFID1();
it will read the tag if at ReadRFID2 but not ReadRFID1
for some resone, it is holding at the first Read and waiting there for a tag to be read how would I make this non-blocking?
chrisnet
Re: multi rfid reader sketch issue
by relaxing on Tue Jul 30, 2019 10:29 am
Looking through the library header... https://github.com/adafruit/Adafruit-PN ... it_PN532.h
...you can see the readPassiveTargetID() function has an optional timeout param that defaults to blocking:
bool readPassiveTargetID(uint8_t cardbaudrate, uint8_t * uid, uint8_t * uidLength, uint16_t timeout = 0); //timeout 0 means no timeout - will block forever.
I think you want to add that timeout parameter to your calls with a reasonable value.
relaxing
by chrisnet on Tue Jul 30, 2019 10:58 am
chrisnet
