Model Railroad Star Wars Project Assistance
by bloseclan on Thu Aug 01, 2019 11:15 pm
I am just starting to get into Arduino’s in order to add animation to model railroad modules.
I am working on a project that will be a Star Wars’ Death Star trench run setup. I will have an x-wing, an advanced tie fighter, and a death star cannon involved. My goal is the following:
a. Push button to start the sequence.
b. LED lights for the x-wing and tie fighter engines (will have fiber optics to the actual vehicles) light up.
c. Sound clip starts of the trench run sequence
d. At W point in time of the sound clip the advanced tie fighter cannons blink
e. At X point in time of the sound clip the death star cannon fires
f. At Y point in time of the sound clip the x-wing tie fighter torpedo shoots. This is run from an electronics module produced by another manufacturer. Basically it will flash two lights.
g. At Z point in time of the sound clip a light flashes once when the torpedo “hits”.
h. The sequence ends.
I have been reading up on your products but am unsure which of your sound shields/devices would best work for me for this project.
I am searching for Arduino sketches to pull pieces from to produce the sketch I will need.
Any suggestions and/or recommendations you can give me would be greatly appreciated.
My electronics knowledge dates back to high school in the mid 1970’s, so am having a steep learning curve.
V/R
Todd Blose
bloseclan
Re: Model Railroad Star Wars Project Assistance
by adafruit_support_bill on Fri Aug 02, 2019 5:49 am
I'd suggest one of the Fx sound boards and an Arduino to keep the time and trigger the sounds and lights.
https://www.adafruit.com/?q=fx
by bloseclan on Fri Aug 02, 2019 8:46 am
The sound and light function would run independently? If so I assume the "trigger" would start the Fx Sound board and the Arduino sketch?
bloseclan
by adafruit_support_bill on Fri Aug 02, 2019 9:48 am
The Arduino would do the timing and coordinate the lights and sounds.
The FX board can play recorded sound clips based on a digital signal trigger - or a serial command. The Arduino is capable of generating either of those.
Most common LEDs can be driven directly from an Arduino pin. We also have multi-channel LED drivers if you run out of pins on the Arduino.
https://www.adafruit.com/product/1455
https://www.adafruit.com/product/1429
