SD Module + LCD = Issue
by Ganderra on Sun Aug 04, 2019 2:34 am
Hey so I have an SD card and module (SD Card FAT32) and I have a file that is Raw text from a .txt format
text is literally just;
CS - 2.8 - 4/8
but when it prints the code onto the lcd I just get a string of numbers (67323246323247)
and on serial its a different string DUEDATES.txt; S-28-48
Code;
if(!key2S) {
        Serial.println("Key 2 has been pressed");
        lcd.clear();
        delay(100);
        lcd.print("Due Dates");
        myFile = SD.open("DUEDATES.txt");
        if (myFile) {
          Serial.println("DUEDATES.txt;");
          lcd.setCursor(0,1);
          // read from the file until there's nothing else in it:
          while (myFile.available()) {
          lcd.print(myFile.read());
          Serial.write(myFile.read());
          myFile.close();
Any ideas to fix?
Could it be with the Baud I'm using
I set it to 57600 because that's what the RTC uses on my board
Ganderra
Re: SD Module + LCD = Issue
by adafruit_support_mike on Sun Aug 04, 2019 5:00 pm
The numbers are the ASCII values of the characters. Use a type cast to make Serial.write() recognize them as characters:
    Serial.write( (char)( myFile.read() ) );
by Ganderra on Sun Aug 04, 2019 5:16 pm
Fixed It :)
Got a friend to help,
        if (myFile) {
          lcd.setCursor(0,1);
            byte nextByte = myFile.read();
            lcd.print((char) nextByte);
            Serial.write((char) nextByte);
          myFile.close();
Ganderra
by adafruit_support_mike on Mon Aug 05, 2019 11:58 am
Glad to hear it. Happy hacking!
cron
