Re: Trouble Using FeatherM0 Adalogger with Arduino IDE
by benclaas7 on Thu Aug 08, 2019 11:02 am
This appears in red in the debugger window when I attempt to upload, if that helps at all:
[Set binary mode
readWord(addr=0)=0x20007ffc
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v2.0 [Arduino:XYZ] Mar 5 2016 17:46:52
chipId=0x10010005
Connected at 921600 baud
Atmel SMART device 0x10010005 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Mar 5 2016 17:46:52
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security : false
Boot Flash : true
readWord(addr=0x40000834)=0x7000a
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 1.011 seconds
Write 32468 bytes to flash (508 pages)
write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x1000)
[=== ] 12% (64/508 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x3000, size=0x1000)
[======= ] 25% (128/508 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x4000, size=0x1000)
[=========== ] 37% (192/508 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x5000, size=0x1000)
[=============== ] 50% (256/508 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x6000, size=0x1000)
[================== ] 62% (320/508 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x7000, size=0x1000)
[====================== ] 75% (384/508 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x8000, size=0x1000)
[========================== ] 88% (448/508 pages)write(addr=0x20005000,size=0xf00)
writeBuffer(scr_addr=0x20005000, dst_addr=0x9000, size=0xf00)
[==============================] 100% (508/508 pages)
done in 0.266 seconds
Verify 32468 bytes of flash with checksum.
checksumBuffer(start_addr=0x2000, size=0x1000) = 3ea
checksumBuffer(start_addr=0x3000, size=0x1000) = e904
checksumBuffer(start_addr=0x4000, size=0x1000) = ef4c
checksumBuffer(start_addr=0x5000, size=0x1000) = bdc6
checksumBuffer(start_addr=0x6000, size=0x1000) = abe3
checksumBuffer(start_addr=0x7000, size=0x1000) = b5d7
checksumBuffer(start_addr=0x8000, size=0x1000) = 7db5
checksumBuffer(start_addr=0x9000, size=0xed4) = 9160
Verify successful
done in 0.074 seconds
CPU reset.
writeWord(addr=0xe000ed0c,value=0x5fa0004)
Couldn't find a Board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.]
