Can Adafruit FX be triggered by Arduino?
by sjw2511 on Wed Aug 21, 2019 3:51 am
I was just wondering if its possible to trigger a sound to play via the adafruit fx seen here https://www.adafruit.com/product/2133 using an arduino?
I want the arduino to play a gun sound at random intervals
Regards
sjw2511
Re: Can Adafruit FX be triggered by Arduino?
by sjw2511 on Wed Aug 21, 2019 5:25 am
This article explains most of what I want to do
https://learn.adafruit.com/adafruit-aud ... io-control
The only remaining question is how do I use the arduino to start playing a track automatically as I wont have access to the serial screen to manually input triggers on my project.
Wondering if I can use serial.write to send the commands automatically??
sjw2511
by adafruit_support_bill on Wed Aug 21, 2019 6:33 am
The Arduino can trigger the Fx via the serial interface or via the trigger pins.
The Arduino Random() function is a simple way to generate random numbers: https://www.arduino.cc/reference/en/lan ... rs/random/
You can use those random numbers to time the intervals between triggers.
by sjw2511 on Wed Aug 21, 2019 6:42 am
Thanks for reply.
To trigger via the pins would i just make the pin high on the arduino?
sjw2511
by adafruit_support_bill on Wed Aug 21, 2019 6:55 am
The trigger pins on the Fx are active LOW, so you would make the pin LOW on the Arduino.
by sjw2511 on Wed Aug 21, 2019 7:06 am
Great cheers!
sjw2511
