HUZZAH ESP8266 Breakout - BLINK compiing error Arduino
by Govner on Fri Dec 13, 2019 4:49 pm
I must be overlooking something pretty basic. Please try to spot it.
The below sketch is the one included in the Product Introduction for HUZZAH ESP8266 breakout board ($9.95), not that it matters. I just tried to 'compile' the sketch and the compiler throws the error at the bottom of this post.
Why is Python even mentioned in the error? That is an exception that I've never seen & don't understand or have a clue about. I verified the options listing in the 'Tools' menu for the chosen board (Adafruit Feather HUZZAH ESP8266). I even uninstalled and re-installed the ESP8266 from the packages/board manager.
All my projects are Arduino-based. I don't use Python for anything so this is a mystery.
      pinMode(0, OUTPUT);
      digitalWrite(0, HIGH);
      delay(500);
      digitalWrite(0, LOW);
      delay(500);
Build options changed, rebuilding all
fork/exec C:\Documents and Settings\Bill\Local Settings\Application Data\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3.exe: %1 is not a valid Win32 application.
Error compiling for board Adafruit Feather HUZZAH ESP8266.
Govner
Re: HUZZAH ESP8266 Breakout - BLINK compiing error Arduino
by philinwisconsin on Wed Dec 18, 2019 10:02 am
Interesting. I have exactly the same problem, only I'm using a Mac. I can't wait to find out what this is about.
Here's my Mac error message:
Arduino: 1.8.5 (Mac OS X), Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:3MB OTA:~512KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
fork/exec /Users/phejtmanek/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3: permission denied
philinwisconsin
by philinwisconsin on Fri Dec 20, 2019 9:55 am
Well, I got it to work. The problem appears to be with the board library package. I had originally installed the latest version (2.6.3), and I received an error on compile (see my previous post). I decided to try an earlier board library package and went with 2.5.2. I installed that version into my Arduino environment and VOILA everything compiled and uploaded to the HUZZAH board just fine. I'm using the Arduino environment 1.8.5 on a mac with osx 10.13.6 High Sierra
I'm concluding that the problem is the 2.6.x library version; perhaps something got hammered up in the evolutionary process...
philinwisconsin
by Govner on Sun Dec 22, 2019 5:42 pm
philinwisconsin wrote:Well, I got it to work. The problem appears to be with the board library package. I had originally installed the latest version (2.6.3), and I received an error on compile (see my previous post). I decided to try an earlier board library package and went with 2.5.2. I installed that version into my Arduino environment and VOILA everything compiled and uploaded to the HUZZAH board just fine.
.....I'm concluding that the problem is the 2.6.x library version; perhaps something got hammered up in the evolutionary process...
I tried this same method but had no luck. I even went back several more library versions but the same // fork...//python// error message is thrown during compile/tests.
Lacking better info about the problem, I guess I'll have to find another route for my ESP8266 solutions. Thanks for your post on the topic.
Regards
PS: Yes, for those wondering, the following gives the same error msg:
      pinMode(13, OUTPUT);
      digitalWrite(13, HIGH);
      delay(500);
      digitalWrite(13, LOW);
      delay(500);
Govner
by BobPicasso on Sun Mar 29, 2020 2:51 pm
There is a problem with a symbolic link to python3
/Users/YourUserName/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3
it points to /usr/local/bin/python3, on my mac but python3 is in /usr/bin/python3.
So, it can be fixed by changing the symbolic link
ln -hfs /usr/bin/python3 /Users/YourUserName/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3
BobPicasso
by philinwisconsin on Mon Mar 30, 2020 8:08 am
Where is this link?? Neither one of us was using python at all.
Thanks.
philinwisconsin
by adafruit_support_carter on Mon Mar 30, 2020 8:31 pm
There's a Python build installed as part of the ESP8266 Board Support Package (BSP). This looks like something has happened with the BSP install for your specific setup. Try re-installing the ESP8266 BSP as a first step and see what happens.
