multiple IR receivers on one Arduino nano
leroylee13
Post by leroylee13 »
I am trying to connect 3 IR sensors (TSOP38238) to an Arduino nano. I am using the IRLib2 library as explained in the adafruit learning subject Using an Infrared Library on Arduino. I am unable to determine if I can use more than one sensor, and if so, what pins will work without timer issues?
zener
Re: multiple IR receivers on one Arduino nano
Post by zener »
I can't answer the question but this might shed some light on it:
https://github.com/z3t0/Arduino-IRremote/issues/20
I am guessing the IRLib2 library would have similar issues.
adafruit_support_mike
IRLib2 uses interrupts IIRC, so it probably doesn't have a way to use more than one sensor. You'd have to deal with all sorts of priority and timing issues.
Disciple
Post by Disciple »
Will the sensors all be watching for the same signal from just one transmitter?
Maybe there's a clever semiconductor way they can share one pin.
Now I'm curious, too.
Hallelujah!
Disciple
gerivega
Post by gerivega »
I have done some modifications on the library. Please try the link https://github.com/gerivega/Arduino-IRremote
Return to “Arduino”
