Errors in moving tilt measurement
Re: Errors in moving tilt measurement
by Adomaino on Mon Mar 02, 2020 10:29 am
In agreement. I give up. I have concluded that the handling of this type of sensors requires high knowledge in this area, despite the fact that a solution to the complex programming of complementary algorithms and filters is offered. In addition to the above, the programming of certain settings is required to adapt it to the intended use. My next steps will be:
1- Try to perform tests with the different modes of use.
2- Lower the sensor to place it as close as possible to the ground so that it moves as little as possible from the real axis of rotation and see if the behavior improves.
3- I will try to contact BOSCH technical support to see if they shed any light on this issue. I will inform you if I find the solution.
Thank you very much for your help.
Adomaino
