Simple RF control with Arduino
by J_Cummings on Tue Feb 04, 2020 9:59 pm
I have configured an arduino uno to use 4 momentary switches to control two servos. I need help with the configuration changes to the sketch and any addition components I may need to replace the switches with the adafruit p/n: 1096 ( simple RF M4 reciever) with p/n: 1095, (4 button RF remote). I am new to arduino and have very little experience with the changes I need to make to make this work. The current configuration has the servos moving when the momentary switches, witch take the associated pins low. The RF module when activated by the remote has 5 volts on the output pins.
Any help with this project will be greatly appreciated.
Thanks again for your time
John
 * Controlling two servos with push buttons. When the left button is press
 * the servo moves left in 10 degree increments. When the right button is
 * press the servo moves right in 10 degree increments.
 #include <Servo.h>
 Servo servo1;  // create servo object servo 1
 Servo servo2;  // creates servo object servo 2
 int angle =90;  // inital angle for servos
 int angleStep =10;  // increment to move servos
 #define S1LEFT 12  // pin 12 connected to servo 1 left button
 #define S1RIGHT 2  // pin 2 connected to servo 1 right button
 #define S2LEFT 8  // pin 8 connected to servo 2 left button
 #define S2RIGHT 4  // pin 4 connected to servo 2 right button
  Serial.begin(9600);   // setup serial
  servo1.attach(9);  // attaches servo 1 to pin 9
  servo2.attach(10);  // attaches servo 2 to pin 10
  pinMode(S1LEFT,INPUT_PULLUP); // assigns pin 12 as input for servo 1 left button
  pinMode(S1RIGHT,INPUT_PULLUP);  // assigns pin 2 as input for servo 1 right button
  pinMode(S2LEFT,INPUT_PULLUP);  // assigns pin 8 as input for servo 2 left button
  pinMode(S2RIGHT,INPUT_PULLUP);  // assigns pin 4 as input for servo 2 right button
   servo1.write(angle);  // sends servo 1 to middle at 90 degress
   servo2.write(angle);  // semds servo 2 to middle at 90 degress
   Serial.println("Servo Button Test");
  while(digitalRead(S1RIGHT) == LOW){
    if (angle > 0 && angle <= 180) {
      angle = angle - angleStep;
      if(angle < 0){
        angle = 0;
      }else{
        servo1.write(angle);  // move servo 1 to desired angle
        Serial.print("Servo 1 move to: ");
        Serial.print(angle);  // print the angle
        Serial.println(" degree");
  delay(100);  // waits for servo to move to position
  }// while
  while(digitalRead(S1LEFT) == LOW){
    if (angle >= 0 && angle + angle <= 180) {
      angle = angle + angleStep;
      if(angle >180){
        angle =180;
      }else{
        Serial.print("Servo 1 moved to: ");
  delay(100);  // waits for servo to get to desired location
  }//while
   while(digitalRead(S2RIGHT) == LOW){
      if(angle < 0){
        angle = 0;
      }else{
        servo2.write(angle);  // move servo 2 to desired angle
        Serial.print("Servo 2 move to: ");
  }// while
  while(digitalRead(S2LEFT) == LOW){
      if(angle >180){
        angle =180;
      }else{
        Serial.print("Servo 2 moved to: ");
servo2v3.ino.ino
(3.07 KiB) Downloaded 3 times
Last edited by adafruit_support_bill on Wed Feb 05, 2020 6:50 am, edited 2 times in total.
Reason: Added code in-line
J_Cummings
Re: Simple RF control with Arduino
by adafruit_support_bill on Wed Feb 05, 2020 6:51 am
code-wise, the only change will be that the outputs of the M4 RF module will go HIGH instead of LOW when the corresponding button on the remote is pressed.
