Itsy Bitsy M0 Express will not Compile
by renefelker on Sat Feb 08, 2020 11:05 pm
Whenever I add the Itsy Bitsy to my Arduino IDE it will not compile. Attempted every solution on line and can not get it to work. I have rebuilt the Raspberry several times and have changed the order of loading the libraries, etc. I coded the "uncanny eyes" last year and it all works, but I am building additional eyes and can not load new Itsy Bitsy's.
/home/pi/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar: error while loading shared libraries: libfl.so.2: cannot open shared object file: No such file or directory
exit status 127
Error compiling for board Adafruit ItsyBitsy M0.
renefelker
Re: Itsy Bitsy M0 Express will not Compile
by dastels on Sun Feb 09, 2020 8:05 pm
Check that you have the Arduino SAMD support installed as well as the Adafruit SAMD support.
dastels
by renefelker on Tue Feb 11, 2020 11:13 am
Thanks for the help. Had all boards and lib needed. The problem was with a shared library. I had to install libfl-dev to get what I needed. In all my troubleshooting I had tried loading it before and it did not fix the problem. But, on my third attempt at rebuilding everything (including PI) I must have hit on the correct load order. It works better if you load the Arduino SAMD boards before the Adafruit SAMD boards.
renefelker
by chuckmoon on Wed Feb 12, 2020 10:01 pm
After fresh install of Arduino 1.8.9 IDE and loading board support for both Arduino and Adafruit SAMD I get error:
Could not find boards.txt in C:\Users\user\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.9. Is it pre-1.5? when I try and run example blinky
chuckmoon
by dastels on Thu Feb 13, 2020 12:01 am
It might be worth upgrading to Arduino 1.8.11
dastels
by chuckmoon on Thu Feb 13, 2020 1:27 am
Initially I started with 1.8.11 and had the problem that was fixed by installing the Arduino SAMD boards (32-bit ARM Cortex-M0+) by Arduino version 1.8.4. So I uninstalled, and started with 1.8.9. I have been able to use my UNO without any issues. I have had similar library issues with my Feather Express M0 and Tinker M0. So, I just upgraded to 1.8.11 and still have the problem. Please advise.
chuckmoon
by dastels on Thu Feb 13, 2020 10:40 am
I'd reinstall the SAM board support in case something got messed up during the Arduino updates.
dastels
by chuckmoon on Thu Feb 13, 2020 11:58 pm
I did and still had an issue. I went looking for boards.txt and it does not have support for feather express M0, itsybitsy M0, or Trinket M0. Arduino shows the proper board is installed.
chuckmoon
by franklin97355 on Fri Feb 14, 2020 12:22 am
You might have to delete the Arduino15 directory and reinstall the board files. Mine have the Adafruit M0 boards listed.
franklin97355
by chuckmoon on Fri Feb 14, 2020 1:26 am
I assume windows 7 is ok?
chuckmoon
by franklin97355 on Fri Feb 14, 2020 1:37 am
I don't know why not.
franklin97355
by chuckmoon on Fri Feb 14, 2020 1:51 pm
I loaded the Arduino IDE 1.8.12 on my windows 10 computer this morning and was able to get "blinky" working :). Attached is the boards.txt file (which I was suprised to see no Tinker M0, ItsyBitsy M0, or Feather Express M0 listed, even though the board manager shows these boards).
Sketch uses 10448 bytes (3%) of program storage space. Maximum is 262144 bytes.
Atmel SMART device 0x10010005 found
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v1.1 [Arduino:XYZ] Feb 5 2018 21:07:26
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
done in 0.847 seconds
Write 10704 bytes to flash (168 pages)
[=========== ] 38% (64/168 pages)
[====================== ] 76% (128/168 pages)
[==============================] 100% (168/168 pages)
done in 0.070 seconds
Verify 10704 bytes of flash with checksum.
Verify successful
done in 0.017 seconds
CPU reset.
Invalid library found in C:\Users\Chuck\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.10\libraries\CI_Tests: no headers files (.h) found in C:\Users\Chuck\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.10\libraries\CI_Tests
Is this from the Python USB mounted drive?
I will uninstall and reinstall Arduino IDE on my two windows 7 computers that have not produced any results and retry. At least now I know my sequence of installation steps is correct and my hardware works. Wish me luck!
boards.txt
After successful Arduino install
(30.98 KiB) Downloaded 3 times
chuckmoon
