i2c 16x4 lcd
i2c 16x4 lcd
by SimpleMan on Wed Feb 12, 2020 7:30 pm
Last Dec. I purchased an Adafruit I2C Controlled + Keypad Shield Kit for 16x2 LCD[ID:715] for an arduino uno r3 based project. At the outset I was going to use a 16x2 display but decided to try using a 16x4 that I had lying around instead. The first two lines work fine with the Adafruit Hello World example, but the 3rd and 4th lines begin in the 5th column. Is there a library or work around that works properly for this configuration? From what I've read, the library seems to be the problem. I've tried many libraries with no success. Currently Adafruit_RGBLCDShield.h is the only library that gives me any degree of success. Any help will be appreciated.
Thank you.
SimpleMan
Re: i2c 16x4 lcd
by SimpleMan on Thu Feb 13, 2020 3:58 pm
Due to lack of response and my own impatience I spent the necessary time to "solve" this on my own. For those who are interested I did the following:
Additional information: The display I am using is a Winstar 16x4 LCD Display Blue Negative Mode White LED Backlight WH1604A-TMI-JT
I downloaded the pdf on the display and discovered the following:
Display Character Address Code
Display Position 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
DD RAM Address 00 01                           0F
DD RAM Address 40 41                           4F
DD RAM Address 10 11                           1F
DD RAM Address 50 51                           5F
I then analyzed the Adafruit_RGBLCDShield.cpp file located in my arduino libraries folder, where I discovered the following line:
int row_offsets[] = { 0x00, 0x40, 0x14, 0x54 };
I changed the line to look like this:
int row_offsets[] = { 0x00, 0x40, 0x10, 0x50 };
This appears to have solved my problem. I offer no guarantees this will solve your problem OR cause additional problems. Use at your own risk!
SimpleMan
