multiple max31865 code issue
by Dre50 on Wed Feb 12, 2020 10:37 pm
Hello i have two max31865 wired together and i worked with the code and what i can figure out is why im getting a reading of -403 F. not sure what i did wrong. when i run the test code with only one board i get the correct reading. can someone help me?
#include <Adafruit_MAX31865.h>
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#include <SPI.h>
// Define LCD pinout
const int  en = 2, rw = 1, rs = 0, d4 = 4, d5 = 5, d6 = 6, d7 = 7, bl = 3;
// Define I2C Address - change if reqiuired
const int i2c_addr = 0x27;
// DHT-22
//#define DHTPIN 7       // DHT-22 Output Pin connection
//#define DHTTYPE DHT11   // DHT Type is DHT 22 (AM2302)
// Define LCD display connections
LiquidCrystal_I2C lcd(i2c_addr, 16, 2);
// SPI.h: CS, DI, DO, CLK
//Adafruit_MAX31865 thermo = Adafruit_MAX31865(10, 11, 12, 13);
// use hardware SPI, just pass in the CS pin
Adafruit_MAX31865 thermo_1 = Adafruit_MAX31865(10);
Adafruit_MAX31865 thermo_2 = Adafruit_MAX31865(9);
// The value of the Rref resistor. Use 430.0 for PT100 and 4300.0 for PT1000
#define RREF      430.0
// The 'nominal' 0-degrees-C resistance of the sensor
// 100.0 for PT100, 1000.0 for PT1000
#define RNOMINAL  100.0
  Serial.begin(115200);
  Serial.println("Adafruit MAX31865 PT100 Sensor Test!");
  lcd.init();
  // Set display type as 16 char, 2 rows
  lcd.begin(16, 2);
  lcd.backlight();
  thermo_1.begin(MAX31865_2WIRE);  // set to 2WIRE or 4WIRE as necessary
  thermo_2.begin(MAX31865_2WIRE);
  uint16_t rtd1 = thermo_1.readRTD();
  Serial.print("RTD value: "); Serial.println(rtd1);
  float ratio1 = rtd1;
  ratio1 /= 32768;
  Serial.print("Ratio1 = "); Serial.println(ratio1, 8);
  Serial.print("Resistance = "); Serial.println(RREF * ratio1, 8);
  Serial.print("Temperature = "); Serial.println(thermo_1.temperature(RNOMINAL, RREF) * 9 / 5 + 32);
  lcd.setCursor(0, 0);
  //lcd.print("Temperature = ");
  lcd.print("Deg.F= ");
  lcd.print(thermo_1.temperature(RNOMINAL, RREF) * 9 / 5 + 32);
  uint16_t rtd2 = thermo_2.readRTD();
  Serial.print("RTD value: "); Serial.println(rtd2);
  float ratio2 = rtd2;
  ratio2 /= 32768;
  Serial.print("Ratio2 = "); Serial.println(ratio2, 8);
  Serial.print("Resistance = "); Serial.println(RREF * ratio2, 8);
  Serial.print("Temperature = "); Serial.println(thermo_2.temperature(RNOMINAL, RREF) * 9 / 5 + 32);
  lcd.setCursor(0, 3);
  lcd.print(thermo_2.temperature(RNOMINAL, RREF) * 9 / 5 + 32);
  delay(1000);
Dre50
Re: multiple max31865 code issue
by adafruit_support_bill on Thu Feb 13, 2020 6:44 am
If you change the test code to address just the second board, do you still get a correct reading?
If you post some photos showing your soldering and wiring, we'll see if we can spot any issues there.
by Dre50 on Thu Feb 13, 2020 5:50 pm
Ok i ran a test and i changed the cs pin on test example code and both boards and both boards read correctly. so its got to be something in my code that's not calculating right or something? any idea?
Dre50
by Dre50 on Thu Feb 13, 2020 6:31 pm
ok I got it working. it didn't like the code i was using so i changed things around and it works now. The only problem i see is that one sensor is 8 deg different the the other? any ideas on that?
#include <Wire.h>
#include <SPI.h>
// DHT-22
Adafruit_MAX31865 thermo1 = Adafruit_MAX31865(9, 11, 12, 13);
//Adafruit_MAX31865 thermo_1 = Adafruit_MAX31865(10);
//Adafruit_MAX31865 thermo_2 = Adafruit_MAX31865(9);
#define RREF      430.0
  lcd.init();
  lcd.begin(16, 2);
  lcd.backlight();
  thermo.begin(MAX31865_2WIRE);  // set to 2WIRE or 4WIRE as necessary
  thermo1.begin(MAX31865_2WIRE);
  uint16_t rtd1 = thermo.readRTD();
  float ratio = rtd1;
  ratio /= 32768;
  Serial.print("Ratio = "); Serial.println(ratio, 8);
  Serial.print("Resistance = "); Serial.println(RREF * ratio, 8);
  Serial.print("Temperature = "); Serial.println(thermo.temperature(RNOMINAL, RREF) * 9 / 5 + 32);
  lcd.print(thermo.temperature(RNOMINAL, RREF) * 9 / 5 + 32);
  uint16_t rtd2 = thermo1.readRTD();
  ratio2 /= 32768;
  Serial.print("Temperature = "); Serial.println(thermo1.temperature(RNOMINAL, RREF) * 9 / 5 + 32);
  lcd.print(thermo1.temperature(RNOMINAL, RREF) * 9 / 5 + 32);
  delay(1000);
Dre50
by adafruit_support_bill on Thu Feb 13, 2020 7:14 pm
Good to hear you have it working. RTDs are generally very accurate - once they have been calibrated. If you perform a 2-point calibration on your 2 RTDs, they should track each other very closely.
https://learn.adafruit.com/calibrating-sensors
by Dre50 on Fri Feb 14, 2020 5:53 pm
Im trying to implement the map() code and keep getting errors any help? im not sure if im doing it right any help thanks.
CorrectedValue = map(RawValue, RawLow, RawHigh, ReferenceLow, ReferenceHigh);
  float ratio = rtd1;
  ratio /= 32768;
 thermo.temperature= map("Temperature = ") 29, 191, 32.3, 210);
Dre50
by Dre50 on Fri Feb 14, 2020 6:45 pm
I found something interesting I swapped sensors and the temp difference stayed with the first board? so is it something in the board? what should i look for there? the resistance is different.
Dre50
by adafruit_support_bill on Fri Feb 14, 2020 7:41 pm
The map function only works with integer values. If you are using floating point values, you need to use the equation as shown in the guide.
Please post some photos showing your soldering and connections to the boards.
by Dre50 on Sat Feb 15, 2020 1:01 pm
adafruit_support_bill wrote:The map function only works with integer values. If you are using floating point values, you need to use the equation as shown in the guide.
so i need to use this formula?
CorrectedValue = (((RawValue – RawLow) * ReferenceRange) / RawRange) + ReferenceLow
Dre50
by adafruit_support_bill on Sat Feb 15, 2020 1:34 pm
Yes. That is essentially what 'map' does. But map converts everything to integer values, so if you are starting with floating point, any fractional values get truncated.
by Dre50 on Sat Feb 15, 2020 3:37 pm
so in my code would i use ("Temperature = ") as my rawvalue?
Dre50
by adafruit_support_bill on Sat Feb 15, 2020 3:54 pm
Yes.
by Dre50 on Sun Feb 16, 2020 6:37 pm
Im getting stray '\342' in program error any idea what I'm missing?
CorrectedValue = ("Temperature = ") – .52) * 99.99) / 72) + .01;
Dre50
by adafruit_support_bill on Sun Feb 16, 2020 7:47 pm
Please post your complete code
by Dre50 on Sun Feb 16, 2020 9:21 pm
#include <Wire.h>
#include <SPI.h>
// DHT-22
#define RREF      430.0
  lcd.init();
  lcd.begin(16, 2);
  lcd.backlight();
  float ratio = rtd1;
  ratio /= 32768;
  ratio2 /= 32768;
  delay(1000);
something isn't right where i have it I'm sure so please help me figure this out I'm new to this.
Dre50
