Confuzles to the maxmoozles (a matter of digital outputs)
by Old_Man_Robo on Wed Feb 26, 2020 2:00 pm
Hello, folks.
I'm having a syntax issue that I don't quite understand. I have two pieces of code: one works and one doesn't. I can't figure out why.
The first piece of code, which is how I originally wrote it, is as follows:
  // put your setup code here, to run once:
  int relay1=2;
  pinMode(relay1, OUTPUT);
  digitalWrite(relay1, HIGH);
delay(1000);
digitalWrite(relay1, LOW);
delay(1000);
When I try to verify this, it highlights the digitalWrite in the loop section and says relay1 has not been declared.
So, I changed the code to this:
  int relay1=2;
delay(1000);
digitalWrite(2, LOW);
delay(1000);
digitalWrite(2, HIGH);
This code verified and worked fine. Can someone explain to me why the first code didn't work but the second code will?
Old_Man_Robo
Re: Confuzles to the maxmoozles (a matter of digital outputs
by adafruit_support_bill on Wed Feb 26, 2020 2:11 pm
Because "relay1" is defined inside the scope of your setup() function. It is not recognized outside of that scope.
If you want relay1 to be recognized everywhere, you need to define it at a global scope:
int relay1=2;
void setup()
void loop()
   delay(1000);
   delay(1000);
by Old_Man_Robo on Wed Feb 26, 2020 2:12 pm
Oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooh!
It's been a while since I've done any programming in this, and I was thinking that the Setup WAS the global scope. Awesome-sauce. Thank you!
Old_Man_Robo
