Arduino Help
Arduino Help
by MARKSSSS on Fri Feb 28, 2020 2:23 pm
Hello, We are unexperienced with arduino. Connecting it to a sparkfun red board. Getting this error,
In file included from C:\Users\sandy\OneDrive\Documents\Arduino\serialthermocouple_2\serialthermocouple_2.ino:18:0:
C:\Users\sandy\OneDrive\Documents\Arduino\libraries\Adafruit_MAX31855_library/Adafruit_MAX31855.h:49:32: warning: passing NULL to non-pointer argument 1 of 'Adafruit_SPIDevice::Adafruit_SPIDevice(int8_t, uint32_t, BitOrder, uint8_t, SPIClass*)' [-Wconversion-null]
Adafruit_SPIDevice spi_dev = NULL;
In file included from C:\Users\sandy\OneDrive\Documents\Arduino\libraries\Adafruit_MAX31855_library\Adafruit_MAX31855.cpp:36:0:
C:\Users\sandy\OneDrive\Documents\Arduino\libraries\Adafruit_MAX31855_library\Adafruit_MAX31855.h:49:32: warning: passing NULL to non-pointer argument 1 of 'Adafruit_SPIDevice::Adafruit_SPIDevice(int8_t, uint32_t, BitOrder, uint8_t, SPIClass*)' [-Wconversion-null]
MARKSSSS
Re: Arduino Help
by kcl1s on Fri Feb 28, 2020 3:51 pm
Posting the code that is giving the error would help. Please use the code button above the edit window and put code between tags.
Fellow hobbyist
Keith
kcl1s
Re: Arduino Help
by nsdev on Wed Mar 04, 2020 1:59 am
Hi We are having the same issue, we are using the sample code provided with the MAX31855 library.
  This is an example for the Adafruit Thermocouple Sensor w/MAX31855K
  Designed specifically to work with the Adafruit Thermocouple Sensor
  ----> https://www.adafruit.com/products/269
  These displays use SPI to communicate, 3 pins are required to
  interface
  products from Adafruit!
  BSD license, all text above must be included in any redistribution
#include <SPI.h>
#include "Adafruit_MAX31855.h"
// Default connection is using software SPI, but comment and uncomment one of
// the two examples below to switch between software SPI and hardware SPI:
// Example creating a thermocouple instance with software SPI on any three
// digital IO pins.
#define MAXDO   3
#define MAXCS   4
#define MAXCLK  5
// initialize the Thermocouple
Adafruit_MAX31855 thermocouple(MAXCLK, MAXCS, MAXDO);
// Example creating a thermocouple instance with hardware SPI
// on a given CS pin.
//#define MAXCS   10
//Adafruit_MAX31855 thermocouple(MAXCS);
  Serial.begin(9600);
  while (!Serial) delay(1); // wait for Serial on Leonardo/Zero, etc
  Serial.println("MAX31855 test");
  // wait for MAX chip to stabilize
  delay(500);
  // basic readout test, just print the current temp
   Serial.print("Internal Temp = ");
   Serial.println(thermocouple.readInternal());
   double c = thermocouple.readCelsius();
   if (isnan(c)) {
     Serial.println("Something wrong with thermocouple!");
   } else {
     Serial.print("C = ");
     Serial.println(c);
   //Serial.print("F = ");
   //Serial.println(thermocouple.readFahrenheit());
   delay(1000);
nsdev
Re: Arduino Help
by trentonmarshall on Sun Mar 15, 2020 2:45 am
Hey,
I'm getting the same error:
In file included from C:\My\Doc\Path\sketch\serialthermocouple.ino:18:0:
D:\Documents\Arduino\libraries\Adafruit_MAX31855_library/Adafruit_MAX31855.h:49:32: warning: passing NULL to non-pointer argument 1 of 'Adafruit_SPIDevice::Adafruit_SPIDevice(int8_t, uint32_t, BitOrder, uint8_t, SPIClass*)' [-Wconversion-null]
Here's the class in the other file that is causing the error:
class Adafruit_MAX31855 {
public:
  Adafruit_MAX31855(int8_t _sclk, int8_t _cs, int8_t _miso);
  Adafruit_MAX31855(int8_t _cs);
  void begin(void);
  double readInternal(void);
  double readCelsius(void);
  double readFahrenheit(void);
  uint8_t readError();
private:
  boolean initialized;
  uint32_t spiread32(void);
trentonmarshall
Re: Arduino Help
by adafruit_support_carter on Mon Mar 16, 2020 1:19 pm
I just did some test compiles for various targets and could not recreate this issue. Can you provide more info:
Arduino IDE Version = ?
Target Board = ?
Target Board BSP Version = ?
MAX31855 Library Version = ?
Re: Arduino Help
by trentonmarshall on Sun Mar 22, 2020 10:03 am
adafruit_support_carter wrote:I just did some test compiles for various targets and could not recreate this issue. Can you provide more info:
Target Board = ?
I've been trying the serialthermocouple example with that error. I tried the lcdthermocouple example and that seemed to work with no errors. I noticed the Wire.h library was included on that one. I included it on the serialthermocouple example and now it seems to be working fine. Is this something that it should work without anyways or is Wire.h necessary?
trentonmarshall
Re: Arduino Help
by adafruit_support_carter on Mon Mar 23, 2020 12:15 pm
That's the same example I tested above and got no errors.
Target Board = ?
Re: Arduino Help
by alainsam on Thu Apr 02, 2020 7:47 pm
Hi
I have the same issue with the Max31855:
Windows10
Arduino IDE Version = 1.8.12
Target Board = UNO
Target Board BSP Version = R3
MAX31855 Library Version = 1.1.1 I also tried the last version with the same result
alainsam
Re: Arduino Help
by alainsam on Fri Apr 03, 2020 12:27 am
I tried these IDE version 1.812 1.8.10 1.8.8 and 1.6.13 with the same problem.
But with the online arduino Create it works!....
I still need to use the IDE on my computer and need a solution.
alainsam
Re: Arduino Help
by alainsam on Fri Apr 03, 2020 1:23 am
alainsam
Re: Arduino Help
by adafruit_support_carter on Fri Apr 03, 2020 11:03 am
One more library to check.
Adafruit BusIO = version?
Re: Arduino Help
by alainsam on Fri Apr 03, 2020 1:35 pm
Is BusIO needed for this MAX 31855?
alainsam
Re: Arduino Help
by alainsam on Fri Apr 03, 2020 1:47 pm
I have these warnings when verifying the sketch:
C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\alain\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\alain\\Documents\\Arduino\\libraries\\Adafruit_MAX31855_library" "C:\\Users\\alain\\Documents\\Arduino\\libraries\\Adafruit_MAX31855_library\\Adafruit_MAX31855.cpp" -o "C:\\Users\\alain\\AppData\\Local\\Temp\\arduino_build_348315\\libraries\\Adafruit_MAX31855_library\\Adafruit_MAX31855.cpp.o"
In file included from C:\Users\alain\Documents\Arduino\libraries\Adafruit_MAX31855_library\
C:\Users\alain\Documents\Arduino\libraries\Adafruit_MAX31855_library\Adafruit_MAX31855.h:49:32:
C:\Users\alain\Documents\Arduino\libraries\Adafruit_MAX31855_library\Adafruit_MAX31855.cpp:
In member function 'uint32_t Adafruit_MAX31855::spiread32()':
C:\Users\alain\Documents\Arduino\libraries\Adafruit_MAX31855_library\Adafruit_MAX31855.cpp:186:7:
warning: unused variable 'i' [-Wunused-variable]
int i;
alainsam
Re: Arduino Help
by adafruit_support_carter on Fri Apr 03, 2020 3:43 pm
SPIDevice comes from the BusIO library:
https://github.com/adafruit/Adafruit_BusIO
Re: Arduino Help
by alainsam on Sun Apr 05, 2020 9:03 pm
I finally found the culprit of my MAX31855 problem: It was a bad connexion on the mini connector of the TC, sometimes it connected sometimes it did not. Kind of error hard to detect. Sorry to have alarmed you.
alainsam
