RadioHead library not working with LoRa32u4 (RFM95) board
by TL57 on Sun Mar 08, 2020 4:25 pm
Hallo,
I have several Adafruit Feather 32u4 RFM95 boards running with the lmic library and a local Lorawan Gateway.
I like to setup low level communication to get more control over response times.
To start I tried the Adafruit Feather9x_TX and Feather9x_RX examples.
For some reason I can not get it working.
For this board I use:
// for Feather32u4 RFM9x
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 7
#define RF95_FREQ 868.0
The init is successful for TX and RX
TX says: No reply, is there a listener around?
RX: does not receive anything if (rf95.available()) is always false.
I tried several units to be sure it is not a hardware issue.
The boards run fine with the lmic library.
Has someone an idea what might be wrong?, thanks.
Below my code:
TX:
// Feather9x_TX
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messaging client (transmitter)
// with the RH_RF95 class. RH_RF95 class does not provide for addressing or
// reliability, so you should only use RH_RF95 if you do not need the higher
// level messaging abilities.
// It is designed to work with the other example Feather9x_RX
#include <SPI.h>
#include <RH_RF95.h>
// for feather32u4
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 7
// Change to 434.0 or other frequency, must match RX's freq!
//#define RF95_FREQ 915.0
// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);
void setup()
  pinMode(RFM95_RST, OUTPUT);
  digitalWrite(RFM95_RST, HIGH);
  Serial.begin(115200);
  while (!Serial) {
    delay(1);
  delay(100);
  Serial.println("Feather LoRa TX Test!");
  // manual reset
  digitalWrite(RFM95_RST, LOW);
  delay(10);
  delay(10);
  while (!rf95.init()) {
    Serial.println("LoRa radio init failed");
    Serial.println("Uncomment '#define SERIAL_DEBUG' in RH_RF95.cpp for detailed debug info");
    while (1);
  Serial.println("LoRa radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
  if (!rf95.setFrequency(RF95_FREQ)) {
    Serial.println("setFrequency failed");
    while (1);
  Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
  // Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
  // The default transmitter power is 13dBm, using PA_BOOST.
  // If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
  // you can set transmitter powers from 5 to 23 dBm:
  rf95.setTxPower(23, false);
int16_t packetnum = 0;  // packet counter, we increment per xmission
void loop()
  delay(1000); // Wait 1 second between transmits, could also 'sleep' here!
  Serial.println("Transmitting..."); // Send a message to rf95_server
  char radiopacket[20] = "Hello World #      ";
  itoa(packetnum++, radiopacket+13, 10);
  Serial.print("Sending "); Serial.println(radiopacket);
  radiopacket[19] = 0;
  Serial.println("Sending...");
  delay(10);
  rf95.send((uint8_t *)radiopacket, 20);
  Serial.println("Waiting for packet to complete...");
  delay(10);
  rf95.waitPacketSent();
  // Now wait for a reply
  uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
  uint8_t len = sizeof(buf);
  Serial.println("Waiting for reply...");
  if (rf95.waitAvailableTimeout(1000))
    // Should be a reply message for us now
    if (rf95.recv(buf, &len))
      Serial.print("Got reply: ");
      Serial.println((char*)buf);
      Serial.print("RSSI: ");
      Serial.println(rf95.lastRssi(), DEC);
    else
      Serial.println("Receive failed");
  else
    Serial.println("No reply, is there a listener around?");
RX:
// Feather9x_RX
// Example sketch showing how to create a simple messaging client (receiver)
// It is designed to work with the other example Feather9x_TX
#include <SPI.h>
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 7
// Blinky on receipt
#define LED 13
void setup()
  pinMode(LED, OUTPUT);
  while (!Serial) {
    delay(1);
  delay(100);
  Serial.println("Feather LoRa RX Test!");
  // manual reset
  delay(10);
  delay(10);
    while (1);
    while (1);
void loop()
    // Should be a message for us now
      digitalWrite(LED, HIGH);
      RH_RF95::printBuffer("Received: ", buf, len);
      Serial.print("Got: ");
      // Send a reply
      uint8_t data[] = "And hello back to you";
      rf95.send(data, sizeof(data));
      Serial.println("Sent a reply");
      digitalWrite(LED, LOW);
    else
TL57
Re: RadioHead library not working with LoRa32u4 (RFM95) boa
by TL57 on Sat Mar 14, 2020 12:07 pm
Eventually the issue was very simple to fix.
When the USB port of my board is not connected "while(!Serial);" is hanging and the application is not started.
Because I had only the client or the server connected to my laptop to check the serial monitor, I did not noticed this.
TL57
