NeoTrellis key press to Serial monitor
by Moris526 on Fri Mar 13, 2020 11:30 pm
Hi.
I want to send the pixel/button number of the neotrellis to the serial monitor.
In the ¨interrupt¨ example from the Seesaw Library I see it should be done in the ¨TrellisCallback¨ part.
I can serial.write a number every time a button is pressed, but i dont know how to get the particular button/pixel .
I leave the code
thanks
/* This example shows basic usage of the NeoTrellis
  with the interrupt pin.
  The buttons will light up various colors when pressed.
#include "Adafruit_NeoTrellis.h"
Adafruit_NeoTrellis trellis;
#define INT_PIN 10
// Input a value 0 to 255 to get a color value.
// The colors are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
   return trellis.pixels.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   return trellis.pixels.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else {
   WheelPos -= 170;
   return trellis.pixels.Color(0, WheelPos * 3, 255 - WheelPos * 3);
//define a callback for key presses
TrellisCallback blink(keyEvent evt){
  if(evt.bit.EDGE == SEESAW_KEYPAD_EDGE_RISING)
    trellis.pixels.setPixelColor(evt.bit.NUM, Wheel(map(evt.bit.NUM, 0, trellis.pixels.numPixels(), 0, 255))); //on rising
  else if(evt.bit.EDGE == SEESAW_KEYPAD_EDGE_FALLING)
    trellis.pixels.setPixelColor(evt.bit.NUM, 0); //off falling
  trellis.pixels.show();
  return 0;
  Serial.begin(9600);
  //while(!Serial);
  pinMode(INT_PIN, INPUT);
  if(!trellis.begin()){
    Serial.println("could not start trellis");
    while(1);
  else{
    Serial.println("trellis started");
  //activate all keys and set callbacks
  for(int i=0; i<NEO_TRELLIS_NUM_KEYS; i++){
    trellis.activateKey(i, SEESAW_KEYPAD_EDGE_RISING);
    trellis.activateKey(i, SEESAW_KEYPAD_EDGE_FALLING);
    trellis.registerCallback(i, blink);
  //do a little animation to show we're on
  for(uint16_t i=0; i<trellis.pixels.numPixels(); i++) {
    trellis.pixels.setPixelColor(i, Wheel(map(i, 0, trellis.pixels.numPixels(), 0, 255)));
    delay(50);
    trellis.pixels.setPixelColor(i, 0x000000);
    delay(50);
  if(!digitalRead(INT_PIN)){
    trellis.read(false);
  delay(2);
Moris526
Re: NeoTrellis key press to Serial monitor
by dastels on Mon Mar 16, 2020 11:16 am
It's there in the code: evt.bit.NUM
dastels
by Moris526 on Wed Mar 18, 2020 12:06 am
Yes.
In serial monitor of arduino appeared empty little squares.
But if i use the max msp serial i get the ascii numbers.
Thnaks
Moris526
by dastels on Wed Mar 18, 2020 9:00 am
Hmm. The serial monitor seems to be trying to display as a character, maybe?
dastels
by Moris526 on Wed Mar 18, 2020 5:54 pm
I guess. Theres a button that displays a Spades from poker cards.
Anyway. I needed to send data to max, and that works fine.
Your answer gave me the idea of checking that.
I ask you another question, just in case you know.
Im trying to supply the adafruit with external power. I try different 5v chargers with no luck.
Any idea?
Thanks.
Moris526
by dastels on Wed Mar 18, 2020 7:18 pm
What have you tried?
dastels
