MAX31865 printing all the errors.
by juliusau93 on Wed Mar 18, 2020 7:53 pm
I followed the instructions for the 3-wire PT100 RTD for the MAX31865 but it gave me errors. When I removed the board is attached and also removed it still gives me 988.79C. I thought the soldering was incomplete but it was. I do not understand what could be the reason.
Fault 0xFF
RTD High Threshold
RTD Low Threshold
REFIN- > 0.85 x Bias
REFIN- < 0.85 x Bias - FORCE- open
RTDIN- < 0.85 x Bias - FORCE- open
Under/Over voltage
Temperature,˚C = 988.79
juliusau93
Re: MAX31865 printing all the errors.
by adafruit_support_bill on Thu Mar 19, 2020 5:09 am
Please post some photos showing your soldering and connections.
by juliusau93 on Thu Mar 19, 2020 12:24 pm
These are the soldering
juliusau93
by juliusau93 on Thu Mar 19, 2020 12:26 pm
one more
juliusau93
by adafruit_support_bill on Thu Mar 19, 2020 1:24 pm
There are a few suspect solder joints there. This guide has some tips on identifying and fixing common soldering problems;
https://learn.adafruit.com/adafruit-gui ... n-problems
The ideal joint should have a cross-section as below:
by juliusau93 on Thu Mar 19, 2020 1:37 pm
I'll cover up the gaps and see what the readings give me. I though as long as there is a connection it should be good.
juliusau93
by adafruit_support_bill on Thu Mar 19, 2020 1:46 pm
Not just the gaps. The joints with too much solder are also suspect, since you can't tell if the solder has actually wetted the solder pad. A very common problem is that the pad was not heated sufficiently. So although the pad is completely covered with solder, there is still a thin layer of oxidation preventing reliable electrical contact.
And checking for continuity with a multimeter is not a meaningful test - since poking the joint with a probe just makes it temporarily more conductive.
by juliusau93 on Mon Mar 30, 2020 12:50 pm
What do you suggest I do? This is my second board and the first one had this issue also.
juliusau93
by adafruit_support_bill on Mon Mar 30, 2020 1:04 pm
Those soldering problems are fixable. Please refer to this guide: https://learn.adafruit.com/adafruit-gui ... n-problems
by juliusau93 on Sat Apr 11, 2020 1:30 pm
I got a new board and soldered it according to the instructions. It is still giving me a 900+C reading. My RTD is a PT100.
juliusau93
by juliusau93 on Sat Apr 11, 2020 1:31 pm
The last picture
juliusau93
by juliusau93 on Sat Apr 11, 2020 2:04 pm
I'm looking at my board at the Rref number. Is the MAX31865 for the Pt100 supposed to say 431 or 430? I have been looking at the images provided upon buying the MAX31865 and I saw 4300 for the PT100. When I got the board it said 431.
juliusau93
by adafruit_support_bill on Sat Apr 11, 2020 2:31 pm
The soldering looks excellent now. And 431 is a correct resistor code for the PT100 reference resistor.
Please post some photos showing your wiring to the processor. And also post the code that you are using.
