Pressure Sensor code (formula) help please
by mjpcarbon on Sat Mar 21, 2020 4:47 pm
Some pressure sensor code help please. My project is to read pressure via a 5v transducer. Can anyone help with a formula that will convert the reading(I assume 0-5v) to a pressure reading. PSI
mjpcarbon
Re: Pressure Sensor code (formula) help please
by adafruit_support_bill on Sat Mar 21, 2020 4:51 pm
What transducer are you using? The spec sheet should tell you how to map the output voltage to a pressure.
by mjpcarbon on Sat Mar 21, 2020 4:56 pm
This is what is given but how do I map it ?
Output: 0.5-4.5V linear voltage output. 0 psi outputs 0.5V, 800 psi outputs 2.5V, 1600 psi outputs 4.5V.
mjpcarbon
by adafruit_support_bill on Sat Mar 21, 2020 7:25 pm
0 psi outputs 0.5V, . . . 1600 psi outputs 4.5V.
So you have the 2 data points needed for a two-point calibration. Just use the two-point calibration calculation from the guide:
https://learn.adafruit.com/calibrating- ... -do-it-5-3
by jim_lee on Sat Mar 21, 2020 7:39 pm
map() is your friend here.
volts = map(analogVal, analogIn1, analogIn2, volts1,volts2); // what volts are we reading? (From Arduino specs.)
psi = map(volts, volts1, volts2, psi1,psi2); // And the pressure that gives us? (From the pressure sensor specs.)
See? No fancy math. Just mappings.
-jim lee
jim_lee
by adafruit_support_bill on Sat Mar 21, 2020 7:47 pm
Unfortunately, the Map function only works with integers. The equation in the calibration guide is essentially the same - but works with floating point values too.
by jim_lee on Sat Mar 21, 2020 8:38 pm
Yes, that can be a, thing. You could just multiply everything by 100 or 1000 do the math then divid it out. Or..
Use mine : https://github.com/leftCoast/Arduino/wiki/mapper
-jim lee
jim_lee
by mjpcarbon on Sat Mar 21, 2020 9:10 pm
Excellent, thanks for the help
mjpcarbon
by mjpcarbon on Sun Mar 22, 2020 11:35 am
Jim, I don't fully understand the example you provided
I expected only to see high and low ranges in the map, don't quite grasp why there are 3 values in the Volts map and the same in the psi map
I realize I am in over my head here and apologize for not understanding the help you have provided
mjpcarbon
by adafruit_support_bill on Sun Mar 22, 2020 12:50 pm
volts1 is the minimum output of the sensor - 0.5v in your case
psi1 is the pressure value that corresponds to volts1 - or 800 psi.
volts2 is the maximum output of the sensor - 4.5v.
psi2 is the pressure that corresponds to volts2 - or 1600 psi.
The first parameter 'volts' is the measured value from your sensor.
by mjpcarbon on Sun Mar 22, 2020 7:34 pm
This is what I have so far, not quite there yet though. The voltage being reported is accurate however the PSI does go up with the voltage but in 400 increments. Seems as thought the PSI is only following the first digit of the voltage * 400.
[code][
int psi = 0;
int volts = 0;
Serial.begin(9600);
int sensorValue = analogRead(A0);
float volts = sensorValue * (5.0 / 1023.0);
//volts = map(volts, 0, 5, .5, 4.5);
psi = map(volts, .5, 4.5, 0, 1600);
Serial.print("PSI = ");
Serial.print(psi);
Serial.print(" Volts = ");
Serial.println(volts);
delay(2000);
/code]
mjpcarbon
by adafruit_support_bill on Sun Mar 22, 2020 8:02 pm
As I mentioned in an earlier post, the Arduino version of map() only works with integer values. You can implement the equation posted above, or try jim_lee's version here: https://github.com/leftCoast/Arduino/wiki/mapper
by jim_lee on Sun Mar 22, 2020 10:03 pm
Here's the actual folder that the mapper stuff is in..
https://github.com/leftCoast/Arduino/tree/master/libraries/LC_baseTools
LC_baseTools is full of very handy & delightful tools, but probably just confusing at this point.
You want mapper.h & mapper.cpp. Luckily they predate most everything in there so they depend on nothing and can "live" on their own.
-jim lee
jim_lee
