Arduino Mac IDE Crashes
by Benshemuel on Sat Mar 21, 2020 11:27 pm
I plugged in a Flora and opened the Arduino IDE on my Mac (2015 MacBook running 10.15.3). The moment I opened a sketch - a small one - the IDE crashed. I updated the IDE and installed board and library updates as it prompted. The IDE continued to crash under various circumstances. I did manage to keep it alive long enough to enable the Flora in Boards Manager and select the USB port the Flora's on.
At this point, I've d/led and installed various versions of the IDE, and in the process, probably screwed up the libraries. When I now load a small test sketch and try to compile and load it onto the Flora, I immediately get this message:
fork/exec /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++: bad CPU type in executable
Error compiling for board Adafruit Flora.
I believe I should clean out my libraries and all vestiges of the IDE and start clean. What's the best path from here?
Ben
Benshemuel
Re: Arduino Mac IDE Crashes
by dastels on Sun Mar 22, 2020 1:41 pm
It definitely looks like something is "out of alignment". Clearing things out and doing a fresh install on all the parts is worth a try.
dastels
by Benshemuel on Sun Mar 22, 2020 9:02 pm
Thanks for confirming, Dave. Any suggestions on how to do a thorough job of that?
Ben
Benshemuel
by dastels on Sun Mar 22, 2020 9:25 pm
It's been a while since I used it on a Mac. I'd start by putting anything obvious in the trash. Then search for "arduino" and "Arduino" and delete look at deleting what you find... carefully... you don't want to delete your sketches.
dastels
by Benshemuel on Tue Mar 24, 2020 12:40 am
Hi Dave,
I noticed that the IDE uses Java, so I d/led and installed the current Java. While the IDE doesn't immediately crash (progress...) I obviously have more to do.
When the There are updated libraries message appears and I click to review and download, I get an alert in the bottom of the Library manager: java.lang.NullPointerException. I also get all this in debug window:
java.lang.RuntimeException: java.lang.NullPointerException
   at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:207)
   at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.NullPointerException
   at cc.arduino.contributions.libraries.ui.ContributedLibraryReleasesComparator.compare(ContributedLibraryReleasesComparator.java:49)
   at cc.arduino.contributions.libraries.ui.ContributedLibraryReleasesComparator.compare(ContributedLibraryReleasesComparator.java:39)
   at java.util.TimSort.mergeHi(TimSort.java:837)
   at java.util.TimSort.mergeAt(TimSort.java:516)
   at java.util.TimSort.mergeCollapse(TimSort.java:441)
   at java.util.TimSort.sort(TimSort.java:245)
   at java.util.Arrays.sort(Arrays.java:1512)
   at java.util.ArrayList.sort(ArrayList.java:1462)
   at java.util.Collections.sort(Collections.java:177)
   at cc.arduino.contributions.libraries.ui.LibrariesIndexTableModel.updateContributions(LibrariesIndexTableModel.java:208)
   at cc.arduino.contributions.libraries.ui.LibrariesIndexTableModel.update(LibrariesIndexTableModel.java:138)
   at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:204)
   ... 1 more
Suggestions?
Thank you,
Ben
Benshemuel
by dastels on Tue Mar 24, 2020 9:33 am
Ugh... that's deep in the Arduino code.
What version of the IDE are you using?
dastels
by Benshemuel on Tue Mar 24, 2020 12:10 pm
1.8.12
B
Benshemuel
by dastels on Tue Mar 24, 2020 12:58 pm
While it's not updating, I just installed the latest on MacOS 10.15.3, and added multiple libraries and board support without an issue.
You cleaned off the old installations of Arduino?
dastels
by Benshemuel on Tue Mar 24, 2020 1:27 pm
I did. I not only deleted the app, I searched for "arduino" and deleted everything related that wasn't in my examples and sketches directories.
Benshemuel
by dastels on Tue Mar 24, 2020 1:37 pm
Have you looked through the Arduino forums? https://forum.arduino.cc/
dastels
by Benshemuel on Tue Mar 24, 2020 9:52 pm
I saw nothing on-point, so I posted. Wish me luck.
Benshemuel
by Benshemuel on Fri Mar 27, 2020 12:46 am
No response there, Dave. I'm dead in the water.
Ben
Benshemuel
