Dallas DS18B20 0,06 degree Celsius swing
by brandtz on Wed Mar 25, 2020 7:09 am
Hi, I need to check with the forum about a 0,06 "swing" up and down on the application I have with a DS18b20. Currently it does not have that pull back resistor, but I might have attached it the wrong way from the beginning, now reading aother posts...Could the resitor issue create this kind of a "swing"?
EasyIoTCloud_data from DS18B20.csv
Excel CSV of some data points
(3.08 KiB) Downloaded 1 time
From EasyIOT chart of data
Easyiot Dallas 18D20 Small swing.JPG (88.65 KiB) Viewed 54 times
brandtz
Re: Dallas DS18B20 0,06 degree Celsius swing
by adafruit_support_bill on Wed Mar 25, 2020 7:19 am
You haven't shown us your code. But used at the highest resolution, the device has a resolution of 0.0625°C.
https://datasheets.maximintegrated.com/ ... S18B20.pdf
by brandtz on Wed Mar 25, 2020 10:30 am
Sorry, here is the Sketch. I guess this is the normal "swing" and nothing wrong with it. Its not that i "need" a better resolution, was just mainly wondering about the "weird jumping around"..
#include <ESP8266WiFi.h>
#include "EIoTCloudRestApiV1.0.h"
#include <EEPROM.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define DEBUG_PROG
#ifdef DEBUG_PROG
  #define DEBUG_PRINTLN(x)  Serial.println(x)
  #define DEBUG_PRINT(x)    Serial.print(x)
#else
#endif
EIoTCloudRestApi eiotcloud;
// change those lines
#define AP_USERNAME "XXXXGuest"
#define AP_PASSWORD "XXXXXuest"
#define INSTANCE_ID "XXXXXXXXXXXXXXXXXX"
#define REPORT_INTERVAL 1
#define ONE_WIRE_BUS D1  // DS18B20 pin
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature DS18B20(&oneWire);
#define CONFIG_START 0
#define CONFIG_VERSION "v01"
struct StoreStruct {
  // This is for mere detection if they are your settings
  char version[4];
  // The variables of your settings
  char token[41];
  uint moduleId;
  //bool tokenOk; // valid token
} storage = {
  CONFIG_VERSION,
  // token
  "XXXXXXXXXXXXXXXXXXXXXXXXX",
  // The default module 0 - invalid module
  0,
  //0 // not valid
String moduleId = "#3";
String parameterId = "XXXXXXXXXXXXXX";
float tempOld = 0;
    Serial.begin(115200);
    DEBUG_PRINTLN("Start...");
    EEPROM.begin(512);
    loadConfig();
    eiotcloud.begin(AP_USERNAME, AP_PASSWORD);
    // if first time get new token and register new module
    // here hapend Plug and play logic to add module to Cloud
    if (storage.moduleId == 0)
      // get new token - alternarive is to manually create token and store it in EEPROM
      String token = eiotcloud.TokenNew(INSTANCE_ID);
      DEBUG_PRINT("Token: ");
      DEBUG_PRINTLN(token);
      eiotcloud.SetToken(token);
      // remember token
      token.toCharArray(storage.token, 41);
      // add new module and configure it
      moduleId = eiotcloud.ModuleNew();
      DEBUG_PRINT("ModuleId: ");
      DEBUG_PRINTLN(moduleId);
      storage.moduleId = moduleId.toInt();
      // set module type
      bool modtyperet = eiotcloud.SetModulType(moduleId, "MT_GENERIC");
      DEBUG_PRINT("SetModulType: ");
      DEBUG_PRINTLN(modtyperet);
      // set module name
      bool modname = eiotcloud.SetModulName(moduleId, "Room temperature");
      DEBUG_PRINT("SetModulName: ");
      DEBUG_PRINTLN(modname);
      // add image settings parameter
      String parameterImgId = eiotcloud.NewModuleParameter(moduleId, "Settings.Icon1");
      DEBUG_PRINT("parameterImgId: ");
      DEBUG_PRINTLN(parameterImgId);
      // set module image
      bool valueRet1 = eiotcloud.SetParameterValue(parameterImgId, "temperature.png");
      DEBUG_PRINT("SetParameterValue: ");
      DEBUG_PRINTLN(valueRet1);
      // now add parameter to display temperature
      parameterId = eiotcloud.NewModuleParameter(moduleId, "Sensor.Parameter1");
      DEBUG_PRINT("ParameterId: ");
      DEBUG_PRINTLN(parameterId);
      //set parameter description
      bool valueRet2 = eiotcloud.SetParameterDescription(parameterId, "Temperature");
      DEBUG_PRINT("SetParameterDescription: ");
      DEBUG_PRINTLN(valueRet2);
      //set unit
      // see http://meyerweb.com/eric/tools/dencoder/ how to encode °C
      bool valueRet3 = eiotcloud.SetParameterUnit(parameterId, "%C2%B0C");
      DEBUG_PRINT("SetParameterUnit: ");
      DEBUG_PRINTLN(valueRet3);
      //Set parameter LogToDatabase
      bool valueRet4 = eiotcloud.SetParameterLogToDatabase(parameterId, true);
      DEBUG_PRINT("SetLogToDatabase: ");
      DEBUG_PRINTLN(valueRet4);
      //SetAvreageInterval
      bool valueRet5 = eiotcloud.SetParameterAverageInterval(parameterId, "10");
      DEBUG_PRINT("SetAvreageInterval: ");
      DEBUG_PRINTLN(valueRet5);
      // save configuration
      saveConfig();
    // if something went wrong, wiat here
      delay(1);
    // read module ID from storage
    moduleId = String(storage.moduleId);
    // read token ID from storage
    eiotcloud.SetToken(storage.token);
    // read Sensor.Parameter1 ID from cloud
    parameterId = eiotcloud.GetModuleParameterByName(moduleId, "Sensor.Parameter1");
    DEBUG_PRINT("parameterId: ");
  float temp;
  do {
    DS18B20.requestTemperatures();
    temp = DS18B20.getTempCByIndex(0);
    DEBUG_PRINT("Temperature: ");
    DEBUG_PRINTLN(temp);
  } while (temp == 85.0 || temp == (-127.0));
  if (tempOld != temp)
    // send temperature
    bool valueRet = eiotcloud.SetParameterValue(parameterId, String(temp));
    DEBUG_PRINTLN(valueRet);
    tempOld = temp;
  delay(1000 * 60 * REPORT_INTERVAL);
void loadConfig() {
  // To make sure there are settings, and they are YOURS!
  // If nothing is found it will use the default settings.
  if (EEPROM.read(CONFIG_START + 0) == CONFIG_VERSION[0] &&
      EEPROM.read(CONFIG_START + 1) == CONFIG_VERSION[1] &&
      EEPROM.read(CONFIG_START + 2) == CONFIG_VERSION[2])
    for (unsigned int t=0; t<sizeof(storage); t++)
      *((char*)&storage + t) = EEPROM.read(CONFIG_START + t);
void saveConfig() {
    EEPROM.write(CONFIG_START + t, *((char*)&storage + t));
  EEPROM.commit();
Arduino Sketch.txt
(5.3 KiB) Downloaded 2 times
Last edited by adafruit_support_bill on Wed Mar 25, 2020 10:54 am, edited 1 time in total.
Reason: added code in-line
brandtz
by adafruit_support_bill on Wed Mar 25, 2020 10:59 am
Being a digital device, it does have a finite resolution. If the actual measurement is right on the edge of one of the quantization steps, the measurement can go either way. And noise is always a factor. As you can see in your graph, as it approaches a step change in the value, the dithering becomes more frequent..
by brandtz on Wed Mar 25, 2020 11:04 am
Thank you very much for your input. Good to know and of course very good explanation. I am so happy I got it to work with EASYIOT and relative the need I have this "swing/sway/dithering" does not effect me.
brandtz
