FAST RESPONSING LASER SENSOR AND ARDUINO BOARD
by sreeji561 on Fri Mar 27, 2020 5:21 am
I would like to measure the displacement of a surface.
-Sampling rate required- 9,000 Samples per second
-Range of displacement 0 to 1m
-Resolution required <1mm
Kindly help me to choose proper board and sensor.
Currently I have used UNO with VL53L0x sensor. This combination works maximum 21 samples per second. Is there any way to get this sensor more fast. Or I should go for new sensor and new board.
sreeji561
Re: FAST RESPONSING LASER SENSOR AND ARDUINO BOARD
by adafruit_support_bill on Fri Mar 27, 2020 6:16 am
We do not carry any rangefinding sensors that operate at the speeds you require.
by sreeji561 on Fri Mar 27, 2020 10:59 am
Can we have sensor with 1000Hz response time with remaining specifications are same.
sreeji561
by adafruit_support_bill on Fri Mar 27, 2020 11:42 am
We do not have any ranging sensors that approach that sample rate.
The theoretical max sample rate for the VL53L0X is about 30 Hz.
The TFMini is a bit faster at about 100 Hz.
https://www.adafruit.com/product/3978
For operation at those speeds, you will probably need to look to industrial grade sensors. Here is one possibility:
https://www.micro-epsilon.com/displacem ... n-sensors/
