App to Contro 6 Servo Motors based from a pca9685l
by DebuA on Sun Apr 05, 2020 10:24 am
Hello!
So, project is to make an app on and connect it to a Arduino uno via HC 05 then use that app to control 6 Servo motors 3xsg90 and 3xMG995 via the PCA9685 board
In my first attempt I just used the Vcc and Gnd available on the pca 9685 to power my servos while the pwm was given via 6 Arduino pins, i.e. I did not use the pwm pins on the pca 9685, it worked flawlessly.
My second attempt is where I need some assistance, this time I connected all my 6 servo motors to my pca9685 gnd>gnd, vcc>vcc and pwm(servo number)>servo
and uploaded the code given below:
#include <SoftwareSerial.h>
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
#include <Servo.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
#define MIN_PULSE_WIDTH 125 // this is the 'minimum' pulse length count (out of 4096)
#define MAX_PULSE_WIDTH 575 // this is the 'maximum' pulse length count (out of 4096)
//#define DEFAULT_PULSE_WIDTH 1500
#define FREQUENCY 60
//uint8_t servonum = 0;
int bluetoothTx = 7;
int bluetoothRx = 4;
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
void setup()
  Serial.begin(38400);
  //Setup Bluetooth serial connection to android
  bluetooth.begin(38400);
  pwm.begin();
  pwm.setPWMFreq(FREQUENCY);
  yield();
void loop()
  int pulse_width, analog_value;
  if(bluetooth.available()>= 2 )
    unsigned int servopos = bluetooth.read();
    unsigned int servopos1 = bluetooth.read();
    unsigned int realservo = (servopos1 *256) + servopos;
    if (realservo >= 1000 && realservo <=1180){
    int servo1 = realservo;
    analog_value=map(servo1, 1000,1180,0,180);
    pulse_width = map(analog_value, 0, 180, MIN_PULSE_WIDTH, MAX_PULSE_WIDTH);
    pwm.setPWM(0, 0, pulse_width);
    Serial.println("Base");
    delay(10);
    if (realservo >=2000 && realservo <=2180){
      int servo2 = realservo;
      analog_value=map(servo2, 2000,2180,0,180);
      pwm.setPWM(1, 0, pulse_width);
      Serial.println("Waist");
      delay(10);
    if (realservo >=3000 && realservo <= 3180){
      int servo3 = realservo;
      analog_value=map(servo3, 3000,3180,0,180);
      pwm.setPWM(2, 0, pulse_width);
      Serial.println("Shoulder");
      delay(10);
    if (realservo >=4000 && realservo <=4180){
      int servo4 = realservo;
      analog_value=map(servo4, 4000,4180,0,180);
      pwm.setPWM(3, 0, pulse_width);
      Serial.println("Elbow");
      delay(10);
    if (realservo >=5000 && realservo <= 5180){
      int servo5 = realservo;
      analog_value=map(servo5, 5000,5180,0,180);
      pwm.setPWM(4, 0, pulse_width);
      Serial.println("Wrist");
      delay(10);
    if (realservo >=6000 && realservo <=6180){
      int servo6 = realservo;
      analog_value=map(servo6, 6000,6180,0,180);
      pwm.setPWM(5, 0, pulse_width);
      Serial.println("Gripper");
      delay(10);
unlike first time when I only used vcc and gnd of pca9685 I used the pwm pin too thus I added the following code that you can see above
the problem is that everything works exactly as I expected except the servos do not rotate at all, I checked the Bluetooth connection too, its good, and prints the related serial.println, that I have added based on what the command the Bluetooth receives so why aren't the servos rotating?
DebuA
Re: App to Contro 6 Servo Motors based from a pca9685l
by adafruit_support_bill on Sun Apr 05, 2020 11:00 am
Have you tested the board using the example code from the library?
by DebuA on Sun Apr 05, 2020 11:53 pm
yeah I have, it works, maybe there is some problem in min and max width
can you please list what general problems are related to PWM control that people face?
DebuA
by adafruit_support_bill on Mon Apr 06, 2020 5:34 am
The min and max pulse widths typically require some tuning per servo for best accuracy. The values in the example code are usually a good starting point.
But if your servos are not moving at all, that suggests a different problem. Please post some photos showing your soldering and connections.
by DebuA on Mon Apr 06, 2020 4:18 pm
Thank you for quick replies, Unfortunately I am not in possession of the physical circuit, it is at my school which is closed due to the outbreak of coronavirus.
Instead of it, I made it on Proteus, image is attached
pca 9685 breakout board: scl > A5, sda>A4, 5V (on pca9685 breakout board)> Vcc (+5v on arduino) and gnd>gnd. I also powered the servo motors using a external battery pack and have connected their signal pin to their respective pwm pin
I cleaned the code a little bit (by removing some unnecessary comments):
this code does not use the pca9685's pwm pin but works fine all motors rotate:
#include <Servo.h>
Servo myservo1, myservo2, myservo3, myservo4, myservo5, myservo6;
void setup()
  myservo1.attach(9);
  myservo2.attach(10);
  myservo3.attach(11);
  myservo4.attach(3);
  myservo5.attach(5);
  myservo6.attach(6);
  //Setup usb serial connection to computer
void loop()
  //Read from bluetooth and write to usb serial
    //Serial.println(realservo);
    servo1 = map(servo1, 1000,1180,0,180);
    myservo1.write(servo1);
    Serial.println("Base_");
    Serial.println(servo1);
    delay(10);
      servo2 = map(servo2,2000,2180,0,180);
      myservo2.write(servo2);
      Serial.println("Waist_");
      Serial.println(servo2);
      delay(10);
      servo3 = map(servo3, 3000, 3180,0,180);
      myservo3.write(servo3);
      Serial.println("Shoulder_");
      Serial.println(servo3);
      delay(10);
      servo4 = map(servo4, 4000, 4180,0,180);
      myservo4.write(servo4);
      Serial.println("Elbow_");
      Serial.println(servo4);
      delay(10);
      servo5 = map(servo5, 5000, 5180,0,180);
      myservo5.write(servo5);
      Serial.println("Wrist_");
      Serial.println(servo5);
      delay(10);
      servo6 = map(servo6, 6000, 6180,0,180);
      myservo6.write(servo6);
      Serial.println("Gripper_");
      Serial.println(servo6);
      delay(10);
but doesn't work when I use the pwm pin on the pca9685 breakout board
#include <Wire.h>
#include <Servo.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40);
#define SERVOMIN  125 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX  575 // this is the 'maximum' pulse length count (out of 4096
void setup()
  pwm.begin();
 // yield();
void loop()
  int angle;
    angle=map(servo1, 1000,1180,0,180);
    pwm.setPWM(0, 0, angleToPulse(angle));
    delay(10);
    angle=map(servo2, 2000,2180,0,180);
    pwm.setPWM(1, 0, angleToPulse(angle));
    delay(10);
    angle=map(servo3, 3000,3180,0,180);
    pwm.setPWM(2, 0, angleToPulse(angle));
    delay(10);
    angle=map(servo4, 4000,4180,0,180);
    pwm.setPWM(3, 0, angleToPulse(angle));
    delay(10);
    angle=map(servo5, 5000,5180,0,180);
    pwm.setPWM(4, 0, angleToPulse(angle));
    delay(10);
    angle=map(servo6, 6000, 6180,0,180);
    pwm.setPWM(5, 0, angleToPulse(angle));
    delay(10);
int angleToPulse(int ang){
   int pulse = map(ang,0, 180, SERVOMIN,SERVOMAX);// map angle of 0 to 180 to Servo min and Servo max
   Serial.print("Angle: ");Serial.print(ang);
   Serial.print(" pulse: ");Serial.println(pulse);
   return pulse;
Screenshot (111).png (46.96 KiB) Viewed 37 times
DebuA
by adafruit_support_bill on Mon Apr 06, 2020 4:27 pm
I do not see a ground connection between the Arduino and the PCA9685. You need a ground connection for a signal reference - as well as a return path for power to the chip.
by DebuA on Mon Apr 06, 2020 4:31 pm
I have connected the gnd on pca > gnd on Arduino:
this is the image I followed:
DebuA
by adafruit_support_bill on Mon Apr 06, 2020 5:53 pm
So, when you run your code, is there any sign of life from any of the servos? Do they twitch or hum? Are you able to turn them by hand?
by DebuA on Thu Apr 09, 2020 9:36 am
It worked!
all I did was changing this
to
I also got to ask, is there a library for pca9685 breakout board available to use in proteus, because in stock proteus all I see is the pca9685 IC?
DebuA
by adafruit_support_bill on Thu Apr 09, 2020 11:06 am
Good to hear you solved it.
All our board files are on Github in EagleCAD format. EagleCAD is a free download and supports export to a number of different formats. You may find one of them to be compatible with Proteus.
https://github.com/adafruit/Adafruit-16 ... Driver-PCB
