Running two ToF Adafruit sensors in two seperate I2C channel
by lvangelis on Wed Apr 08, 2020 12:51 pm
I am trying to initiate the TwoWire function to run two Adafruit toF sensors. The message I get is that they fail to boot and poll no data. Code returns no errors and sensors can be found using the I2C dual scanner method. They also polling if I run independently. Its early days in Arduino so not sure if I am doing something obviously wrong here. Any help would be appreciated.
#include "Adafruit_VL53L0X.h"
#include "Adafruit_VL6180X.h"
#include <Wire.h>
#define SDA1 21
#define SCL1 22
#define SDA2 5
#define SCL2 4
TwoWire WireA = TwoWire(0);
TwoWire WireB = TwoWire(1);
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
Adafruit_VL6180X vl = Adafruit_VL6180X();
float lux = 0.;
uint8_t range = 0;
uint16_t secrange = 0;
  Serial.begin(115200);
  WireA.begin(SDA1, SCL1, 100000); //uses default SDA and SCL and 100000HZ freq
  WireB.begin(SDA2, SCL2, 100000); //uses default SDA and SCL and 100000HZ freq
  // wait until serial port opens for native USB devices
  while (! Serial) {
    delay(1);
  vl.begin();
  lox.begin();
      Serial.println("Adafruit VL53L0X test");
  if (!lox.begin()) {
    Serial.println(F("Failed to boot VL53L0X"));
    while(1);
  // power
  Serial.println(F("VL53L0X API Simple Ranging example\n\n"));
  Serial.println("Adafruit VL6180x test!");
  if (! vl.begin()) {
    Serial.println("Failed to find sensor");
    while (1);
  VL53L0X_RangingMeasurementData_t measure;
  secrange = measure.RangeMilliMeter;
  Serial.print("Reading a measurement... ");
  lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
  if (measure.RangeStatus != 4) {  // phase failures have incorrect data
    Serial.print("Distance (mm): "); Serial.println(measure.RangeMilliMeter);
  } else {
    Serial.println(" out of range ");
  lux = vl.readLux(VL6180X_ALS_GAIN_5);
  Serial.print("Lux: "); Serial.println(lux);
  range = vl.readRange();
  uint8_t status = vl.readRangeStatus();
  if (status == VL6180X_ERROR_NONE) {
  Serial.print("Range: "); Serial.println(range);
  // Some error occurred, print it out!
  if  ((status >= VL6180X_ERROR_SYSERR_1) && (status <= VL6180X_ERROR_SYSERR_5)) {
    Serial.println("System error");
  else if (status == VL6180X_ERROR_ECEFAIL) {
    Serial.println("ECE failure");
  else if (status == VL6180X_ERROR_NOCONVERGE) {
    Serial.println("No convergence");
  else if (status == VL6180X_ERROR_RANGEIGNORE) {
    Serial.println("Ignoring range");
  else if (status == VL6180X_ERROR_SNR) {
    Serial.println("Signal/Noise error");
  else if (status == VL6180X_ERROR_RAWUFLOW) {
    Serial.println("Raw reading underflow");
  else if (status == VL6180X_ERROR_RAWOFLOW) {
    Serial.println("Raw reading overflow");
  else if (status == VL6180X_ERROR_RANGEUFLOW) {
    Serial.println("Range reading underflow");
  else if (status == VL6180X_ERROR_RANGEOFLOW) {
    Serial.println("Range reading overflow");
  delay(100);
Last edited by adafruit_support_carter on Fri Apr 10, 2020 4:26 pm, edited 1 time in total.
Reason: added [code] tags
lvangelis
Re: Running two ToF Adafruit sensors in two seperate I2C cha
by adafruit_support_carter on Fri Apr 10, 2020 4:27 pm
Start simple. Set each one up individually and run the basic demo example from the library for each. Prove they each work separately before combing them.
