Adafruit Grand Central M4 Express
by Migueliyo on Fri Apr 10, 2020 7:28 am
Hello my name is Miguel from Spain and I have a problem with the board does not appear on the board list of the arduino library. I have followed these steps (https://learn.adafruit.com/adafruit-gra ... rduino-ide) but I am not successful. I have installed the pack Arduino SAMD ( 32-bits ARM Cortex-M0+) Boards but not appear this board "Grand Central M4 Express" as it appears in the tutorial.
Migueliyo
Re: Adafruit Grand Central M4 Express
by dastels on Fri Apr 10, 2020 9:17 am
Did you also install/update the Adafruit SAMD board package?
dastels
by Migueliyo on Fri Apr 10, 2020 10:08 am
I have successfully installed the package from Arduino named "Arduino SAMD Boards" and installed version 1.8.6 which I think is the last since Arduino there is no package with the name "Adafruit SAMD board package" I need help please I have to install it on a broken 3D printer to make masks.
Migueliyo
by dastels on Fri Apr 10, 2020 10:37 am
Instructions are in the Grand Central tutorial, specifically: https://learn.adafruit.com/adafruit-grand-central/setup.
dastels
by Migueliyo on Fri Apr 10, 2020 11:48 am
Thank you very much :) I have managed to apply the board in arduino "Adafruit Grand Central M4 Express" corresponds to "Adafruit Feather M4 Express (SAMD51)".
Now I have a compilation error:
In file included from sketch \ Marlin.ino.cpp: 1: 0:
C: \ Users \ Miguel-iyo \ AppData \ Local \ Arduino15 \ packages \ adafruit \ hardware \ samd \ 1.5.11 \ cores \ arduino / Arduino.h: 48: 10: fatal error: sam.h: No such file or directory
  #include "sam.h"
compilation terminated.
exit status 1
Compiling error for Adafruit Feather M4 Express card (SAMD51).
I have followed these steps, but I am not doing something correctly.
https://learn.adafruit.com/adafruit-gra ... ches-to-m0
Migueliyo
by dastels on Fri Apr 10, 2020 11:59 am
"GrandCentral M4 Express" and "Feather M4 Express" are two different boards, with two different MCUs (although they share the ARM Cortex-M4 core). You need to select the appropriate board.
dastels
by Migueliyo on Fri Apr 10, 2020 12:48 pm
I have chosen Adafruit Grand Central M4 (SAMD51) accordingly.
but I have a lot of errors:
This compilation works well with the arduino mega 2560 board with a shiel ramps 1.4 this compilation belongs to a Cartesian printer (Anet A8) and works at 8 bits. I imagine it influences compilation since Adafruit Grand Central M4 Express is a 32-bit board..
Currently I am going to use Adafruit Grand Central M4 Express with the Ramps 1.6 shield is fully compatible.
It seems like a complicated project for this board there are too many errors:
ATTENTION: the U8glib library intends to run on avr, sam architecture (s) and may be incompatible with your current card which runs on architecture (s) samd.
In file included from C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/Arduino.h:66:0,
from sketch\Marlin.ino.cpp:1:
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/WVariant.h:182:40: error: 'TCC_INST_NUM' was not declared in this scope
extern const uint32_t GCLK_CLKCTRL_IDs[TCC_INST_NUM+TC_INST_NUM];
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/WVariant.h:182:53: error: 'TC_INST_NUM' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/WVariant.h:257:36: error: 'TCC_INST_NUM' was not declared in this scope
extern const void* g_apTCInstances[TCC_INST_NUM+TC_INST_NUM] ;
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/WVariant.h:257:49: error: 'TC_INST_NUM' was not declared in this scope
In file included from C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\variants\grand_central_m4/variant.h:46:0,
from C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/delay.h:24,
from C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/Arduino.h:81,
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/SERCOM.h:171:16: error: expected ')' before '*' token
SERCOM(Sercom* s) ;
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/SERCOM.h:254:3: error: 'Sercom' does not name a type; did you mean 'Stream'?
Sercom* sercom;
Stream
In file included from C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/USBAPI.h:37:0,
from C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/Arduino.h:158,
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:175:2: error: 'UsbDevice' does not name a type
UsbDevice &usb;
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:178:34: error: 'UsbDeviceDescriptor' does not name a type; did you mean 'DeviceDescriptor'?
__attribute__((__aligned__(4))) UsbDeviceDescriptor EP[USB_EPT_NUM];
DeviceDescriptor
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In constructor 'USBDevice_SAMD21G18x::USBDevice_SAMD21G18x()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:32:27: error: class 'USBDevice_SAMD21G18x' does not have any field named 'usb'
USBDevice_SAMD21G18x() : usb(USB->DEVICE) {
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:32:31: error: 'USB' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::enable()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:44:3: error: 'usb' was not declared in this scope
usb.CTRLA.bit.ENABLE = 1;
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:46:29: error: 'USB_SYNCBUSY_ENABLE' was not declared in this scope
while( usb.SYNCBUSY.reg & USB_SYNCBUSY_ENABLE ); //wait for sync
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::disable()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:50:3: error: 'usb' was not declared in this scope
usb.CTRLA.bit.ENABLE = 0;
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:52:29: error: 'USB_SYNCBUSY_ENABLE' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::setUSBDeviceMode()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:57:35: error: 'usb' was not declared in this scope
inline void setUSBDeviceMode() { usb.CTRLA.bit.MODE = USB_CTRLA_MODE_DEVICE_Val; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:57:56: error: 'USB_CTRLA_MODE_DEVICE_Val' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::setUSBHostMode()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:58:35: error: 'usb' was not declared in this scope
inline void setUSBHostMode() { usb.CTRLA.bit.MODE = USB_CTRLA_MODE_HOST_Val; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:58:56: error: 'USB_CTRLA_MODE_HOST_Val' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::runInStandby()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:60:33: error: 'usb' was not declared in this scope
inline void runInStandby() { usb.CTRLA.bit.RUNSTDBY = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::noRunInStandby()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:61:33: error: 'usb' was not declared in this scope
inline void noRunInStandby() { usb.CTRLA.bit.RUNSTDBY = 0; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::wakeupHost()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:62:33: error: 'usb' was not declared in this scope
inline void wakeupHost() { usb.CTRLB.bit.UPRSM = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::setFullSpeed()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:65:37: error: 'usb' was not declared in this scope
inline void setFullSpeed() { usb.CTRLB.bit.SPDCONF = USB_DEVICE_CTRLB_SPDCONF_FS_Val; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:65:61: error: 'USB_DEVICE_CTRLB_SPDCONF_FS_Val' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::setLowSpeed()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:66:37: error: 'usb' was not declared in this scope
inline void setLowSpeed() { usb.CTRLB.bit.SPDCONF = USB_DEVICE_CTRLB_SPDCONF_LS_Val; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:66:61: error: 'USB_DEVICE_CTRLB_SPDCONF_LS_Val' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::setHiSpeed()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:67:37: error: 'usb' was not declared in this scope
inline void setHiSpeed() { usb.CTRLB.bit.SPDCONF = USB_DEVICE_CTRLB_SPDCONF_HS_Val; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:67:61: error: 'USB_DEVICE_CTRLB_SPDCONF_HS_Val' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::setHiSpeedTestMode()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:68:37: error: 'usb' was not declared in this scope
inline void setHiSpeedTestMode() { usb.CTRLB.bit.SPDCONF = USB_DEVICE_CTRLB_SPDCONF_HSTM_Val; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:68:61: error: 'USB_DEVICE_CTRLB_SPDCONF_HSTM_Val' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:68:61: note: suggested alternative: 'USB_DEVICE_CLASS_STORAGE'
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::attach()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:71:25: error: 'usb' was not declared in this scope
inline void attach() { usb.CTRLB.bit.DETACH = 0; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::detach()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:72:25: error: 'usb' was not declared in this scope
inline void detach() { usb.CTRLB.bit.DETACH = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'bool USBDevice_SAMD21G18x::isEndOfResetInterrupt()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:75:54: error: 'usb' was not declared in this scope
inline bool isEndOfResetInterrupt() { return usb.INTFLAG.bit.EORST; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::ackEndOfResetInterrupt()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:76:47: error: 'usb' was not declared in this scope
inline void ackEndOfResetInterrupt() { usb.INTFLAG.reg = USB_DEVICE_INTFLAG_EORST; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:76:65: error: 'USB_DEVICE_INTFLAG_EORST' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:76:65: note: suggested alternative: 'USB_DEVICE_QUALIFIER'
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::enableEndOfResetInterrupt()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:77:47: error: 'usb' was not declared in this scope
inline void enableEndOfResetInterrupt() { usb.INTENSET.bit.EORST = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::disableEndOfResetInterrupt()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:78:47: error: 'usb' was not declared in this scope
inline void disableEndOfResetInterrupt() { usb.INTENCLR.bit.EORST = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'bool USBDevice_SAMD21G18x::isStartOfFrameInterrupt()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:80:54: error: 'usb' was not declared in this scope
inline bool isStartOfFrameInterrupt() { return usb.INTFLAG.bit.SOF; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::ackStartOfFrameInterrupt()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:81:47: error: 'usb' was not declared in this scope
inline void ackStartOfFrameInterrupt() { usb.INTFLAG.reg = USB_DEVICE_INTFLAG_SOF; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:81:65: error: 'USB_DEVICE_INTFLAG_SOF' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:81:65: note: suggested alternative: 'USB_DEVICE_QUALIFIER'
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::enableStartOfFrameInterrupt()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:82:47: error: 'usb' was not declared in this scope
inline void enableStartOfFrameInterrupt() { usb.INTENSET.bit.SOF = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::disableStartOfFrameInterrupt()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:83:47: error: 'usb' was not declared in this scope
inline void disableStartOfFrameInterrupt() { usb.INTENCLR.bit.SOF = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::setAddress(uint32_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:86:44: error: 'usb' was not declared in this scope
inline void setAddress(uint32_t addr) { usb.DADD.bit.DADD = addr; usb.DADD.bit.ADDEN = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::unsetAddress()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:87:44: error: 'usb' was not declared in this scope
inline void unsetAddress() { usb.DADD.bit.DADD = 0; usb.DADD.bit.ADDEN = 0; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'uint16_t USBDevice_SAMD21G18x::frameNumber()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:90:41: error: 'usb' was not declared in this scope
inline uint16_t frameNumber() { return usb.FNUM.bit.FNUM; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0SetType(ep_t, uint8_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:99:54: error: 'usb' was not declared in this scope
inline void epBank0SetType(ep_t ep, uint8_t type) { usb.DeviceEndpoint[ep].EPCFG.bit.EPTYPE0 = type; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1SetType(ep_t, uint8_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:100:54: error: 'usb' was not declared in this scope
inline void epBank1SetType(ep_t ep, uint8_t type) { usb.DeviceEndpoint[ep].EPCFG.bit.EPTYPE1 = type; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'uint16_t USBDevice_SAMD21G18x::epInterruptSummary()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:103:48: error: 'usb' was not declared in this scope
inline uint16_t epInterruptSummary() { return usb.EPINTSMRY.reg; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'bool USBDevice_SAMD21G18x::epBank0IsSetupReceived(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:105:59: error: 'usb' was not declared in this scope
inline bool epBank0IsSetupReceived(ep_t ep) { return usb.DeviceEndpoint[ep].EPINTFLAG.bit.RXSTP; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'bool USBDevice_SAMD21G18x::epBank0IsStalled(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:106:59: error: 'usb' was not declared in this scope
inline bool epBank0IsStalled(ep_t ep) { return usb.DeviceEndpoint[ep].EPINTFLAG.bit.STALL0; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'bool USBDevice_SAMD21G18x::epBank1IsStalled(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:107:59: error: 'usb' was not declared in this scope
inline bool epBank1IsStalled(ep_t ep) { return usb.DeviceEndpoint[ep].EPINTFLAG.bit.STALL1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'bool USBDevice_SAMD21G18x::epBank0IsTransferComplete(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:108:59: error: 'usb' was not declared in this scope
inline bool epBank0IsTransferComplete(ep_t ep) { return usb.DeviceEndpoint[ep].EPINTFLAG.bit.TRCPT0; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'bool USBDevice_SAMD21G18x::epBank1IsTransferComplete(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:109:59: error: 'usb' was not declared in this scope
inline bool epBank1IsTransferComplete(ep_t ep) { return usb.DeviceEndpoint[ep].EPINTFLAG.bit.TRCPT1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0AckSetupReceived(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:111:52: error: 'usb' was not declared in this scope
inline void epBank0AckSetupReceived(ep_t ep) { usb.DeviceEndpoint[ep].EPINTFLAG.reg = USB_DEVICE_EPINTFLAG_RXSTP; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:111:91: error: 'USB_DEVICE_EPINTFLAG_RXSTP' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:111:91: note: suggested alternative: 'USB_DEVICE_QUALIFIER'
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0AckStalled(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:112:52: error: 'usb' was not declared in this scope
inline void epBank0AckStalled(ep_t ep) { usb.DeviceEndpoint[ep].EPINTFLAG.reg = USB_DEVICE_EPINTFLAG_STALL(1); }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:112:91: error: 'USB_DEVICE_EPINTFLAG_STALL' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:112:91: note: suggested alternative: 'USB_DEVICE_CLASS_STORAGE'
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1AckStalled(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:113:52: error: 'usb' was not declared in this scope
inline void epBank1AckStalled(ep_t ep) { usb.DeviceEndpoint[ep].EPINTFLAG.reg = USB_DEVICE_EPINTFLAG_STALL(2); }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:113:91: error: 'USB_DEVICE_EPINTFLAG_STALL' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:113:91: note: suggested alternative: 'USB_DEVICE_CLASS_STORAGE'
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0AckTransferComplete(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:114:52: error: 'usb' was not declared in this scope
inline void epBank0AckTransferComplete(ep_t ep) { usb.DeviceEndpoint[ep].EPINTFLAG.reg = USB_DEVICE_EPINTFLAG_TRCPT(1); }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:114:91: error: 'USB_DEVICE_EPINTFLAG_TRCPT' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:114:91: note: suggested alternative: 'USB_DEVICE_DESCRIPTOR_TYPE'
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1AckTransferComplete(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:115:52: error: 'usb' was not declared in this scope
inline void epBank1AckTransferComplete(ep_t ep) { usb.DeviceEndpoint[ep].EPINTFLAG.reg = USB_DEVICE_EPINTFLAG_TRCPT(2); }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:115:91: error: 'USB_DEVICE_EPINTFLAG_TRCPT' was not declared in this scope
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:115:91: note: suggested alternative: 'USB_DEVICE_DESCRIPTOR_TYPE'
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0EnableSetupReceived(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:117:55: error: 'usb' was not declared in this scope
inline void epBank0EnableSetupReceived(ep_t ep) { usb.DeviceEndpoint[ep].EPINTENSET.bit.RXSTP = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0EnableStalled(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:118:55: error: 'usb' was not declared in this scope
inline void epBank0EnableStalled(ep_t ep) { usb.DeviceEndpoint[ep].EPINTENSET.bit.STALL0 = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1EnableStalled(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:119:55: error: 'usb' was not declared in this scope
inline void epBank1EnableStalled(ep_t ep) { usb.DeviceEndpoint[ep].EPINTENSET.bit.STALL1 = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0EnableTransferComplete(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:120:55: error: 'usb' was not declared in this scope
inline void epBank0EnableTransferComplete(ep_t ep) { usb.DeviceEndpoint[ep].EPINTENSET.bit.TRCPT0 = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1EnableTransferComplete(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:121:55: error: 'usb' was not declared in this scope
inline void epBank1EnableTransferComplete(ep_t ep) { usb.DeviceEndpoint[ep].EPINTENSET.bit.TRCPT1 = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0DisableSetupReceived(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:123:56: error: 'usb' was not declared in this scope
inline void epBank0DisableSetupReceived(ep_t ep) { usb.DeviceEndpoint[ep].EPINTENCLR.bit.RXSTP = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0DisableStalled(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:124:56: error: 'usb' was not declared in this scope
inline void epBank0DisableStalled(ep_t ep) { usb.DeviceEndpoint[ep].EPINTENCLR.bit.STALL0 = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1DisableStalled(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:125:56: error: 'usb' was not declared in this scope
inline void epBank1DisableStalled(ep_t ep) { usb.DeviceEndpoint[ep].EPINTENCLR.bit.STALL1 = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0DisableTransferComplete(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:126:56: error: 'usb' was not declared in this scope
inline void epBank0DisableTransferComplete(ep_t ep) { usb.DeviceEndpoint[ep].EPINTENCLR.bit.TRCPT0 = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1DisableTransferComplete(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:127:56: error: 'usb' was not declared in this scope
inline void epBank1DisableTransferComplete(ep_t ep) { usb.DeviceEndpoint[ep].EPINTENCLR.bit.TRCPT1 = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'bool USBDevice_SAMD21G18x::epBank0IsReady(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:130:50: error: 'usb' was not declared in this scope
inline bool epBank0IsReady(ep_t ep) { return usb.DeviceEndpoint[ep].EPSTATUS.bit.BK0RDY; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'bool USBDevice_SAMD21G18x::epBank1IsReady(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:131:50: error: 'usb' was not declared in this scope
inline bool epBank1IsReady(ep_t ep) { return usb.DeviceEndpoint[ep].EPSTATUS.bit.BK1RDY; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0SetReady(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:132:43: error: 'usb' was not declared in this scope
inline void epBank0SetReady(ep_t ep) { usb.DeviceEndpoint[ep].EPSTATUSSET.bit.BK0RDY = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1SetReady(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:133:43: error: 'usb' was not declared in this scope
inline void epBank1SetReady(ep_t ep) { usb.DeviceEndpoint[ep].EPSTATUSSET.bit.BK1RDY = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0ResetReady(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:134:43: error: 'usb' was not declared in this scope
inline void epBank0ResetReady(ep_t ep) { usb.DeviceEndpoint[ep].EPSTATUSCLR.bit.BK0RDY = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1ResetReady(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:135:43: error: 'usb' was not declared in this scope
inline void epBank1ResetReady(ep_t ep) { usb.DeviceEndpoint[ep].EPSTATUSCLR.bit.BK1RDY = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0SetStallReq(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:137:46: error: 'usb' was not declared in this scope
inline void epBank0SetStallReq(ep_t ep) { usb.DeviceEndpoint[ep].EPSTATUSSET.bit.STALLRQ0 = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1SetStallReq(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:138:46: error: 'usb' was not declared in this scope
inline void epBank1SetStallReq(ep_t ep) { usb.DeviceEndpoint[ep].EPSTATUSSET.bit.STALLRQ1 = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0ResetStallReq(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:139:46: error: 'usb' was not declared in this scope
inline void epBank0ResetStallReq(ep_t ep) { usb.DeviceEndpoint[ep].EPSTATUSCLR.bit.STALLRQ0 = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1ResetStallReq(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:140:46: error: 'usb' was not declared in this scope
inline void epBank1ResetStallReq(ep_t ep) { usb.DeviceEndpoint[ep].EPSTATUSCLR.bit.STALLRQ1 = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'uint16_t USBDevice_SAMD21G18x::epBank0ByteCount(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:143:53: error: 'EP' was not declared in this scope
inline uint16_t epBank0ByteCount(ep_t ep) { return EP[ep].DeviceDescBank[0].PCKSIZE.bit.BYTE_COUNT; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:143:53: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'uint16_t USBDevice_SAMD21G18x::epBank1ByteCount(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:144:53: error: 'EP' was not declared in this scope
inline uint16_t epBank1ByteCount(ep_t ep) { return EP[ep].DeviceDescBank[1].PCKSIZE.bit.BYTE_COUNT; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:144:53: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0SetByteCount(ep_t, uint16_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:145:58: error: 'EP' was not declared in this scope
inline void epBank0SetByteCount(ep_t ep, uint16_t bc) { EP[ep].DeviceDescBank[0].PCKSIZE.bit.BYTE_COUNT = bc; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:145:58: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1SetByteCount(ep_t, uint16_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:146:58: error: 'EP' was not declared in this scope
inline void epBank1SetByteCount(ep_t ep, uint16_t bc) { EP[ep].DeviceDescBank[1].PCKSIZE.bit.BYTE_COUNT = bc; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:146:58: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0SetMultiPacketSize(ep_t, uint16_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:147:63: error: 'EP' was not declared in this scope
inline void epBank0SetMultiPacketSize(ep_t ep, uint16_t s) { EP[ep].DeviceDescBank[0].PCKSIZE.bit.MULTI_PACKET_SIZE = s; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:147:63: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1SetMultiPacketSize(ep_t, uint16_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:148:63: error: 'EP' was not declared in this scope
inline void epBank1SetMultiPacketSize(ep_t ep, uint16_t s) { EP[ep].DeviceDescBank[1].PCKSIZE.bit.MULTI_PACKET_SIZE = s; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:148:63: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0SetAddress(ep_t, void*)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:150:55: error: 'EP' was not declared in this scope
inline void epBank0SetAddress(ep_t ep, void *addr) { EP[ep].DeviceDescBank[0].ADDR.reg = (uint32_t)addr; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:150:55: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1SetAddress(ep_t, void*)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:151:55: error: 'EP' was not declared in this scope
inline void epBank1SetAddress(ep_t ep, void *addr) { EP[ep].DeviceDescBank[1].ADDR.reg = (uint32_t)addr; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:151:55: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0SetSize(ep_t, uint16_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:152:55: error: 'EP' was not declared in this scope
inline void epBank0SetSize(ep_t ep, uint16_t size) { EP[ep].DeviceDescBank[0].PCKSIZE.bit.SIZE = EP_PCKSIZE_SIZE(size); }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:152:55: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1SetSize(ep_t, uint16_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:153:55: error: 'EP' was not declared in this scope
inline void epBank1SetSize(ep_t ep, uint16_t size) { EP[ep].DeviceDescBank[1].PCKSIZE.bit.SIZE = EP_PCKSIZE_SIZE(size); }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:153:55: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0DisableAutoZLP(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:168:47: error: 'EP' was not declared in this scope
inline void epBank0DisableAutoZLP(ep_t ep) { EP[ep].DeviceDescBank[0].PCKSIZE.bit.AUTO_ZLP = 0; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:168:47: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1DisableAutoZLP(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:169:47: error: 'EP' was not declared in this scope
inline void epBank1DisableAutoZLP(ep_t ep) { EP[ep].DeviceDescBank[1].PCKSIZE.bit.AUTO_ZLP = 0; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:169:47: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank0EnableAutoZLP(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:170:47: error: 'EP' was not declared in this scope
inline void epBank0EnableAutoZLP(ep_t ep) { EP[ep].DeviceDescBank[0].PCKSIZE.bit.AUTO_ZLP = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:170:47: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In member function 'void USBDevice_SAMD21G18x::epBank1EnableAutoZLP(ep_t)':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:171:47: error: 'EP' was not declared in this scope
inline void epBank1EnableAutoZLP(ep_t ep) { EP[ep].DeviceDescBank[1].PCKSIZE.bit.AUTO_ZLP = 1; }
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:171:47: note: suggested alternative: 'EP0'
EP0
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In constructor '__Guard::__Guard()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:188:22: error: '__get_PRIMASK' was not declared in this scope
__Guard() : primask(__get_PRIMASK()), loops(1) {
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:188:22: note: suggested alternative: '__PRIMAX'
__PRIMAX
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:189:3: error: '__disable_irq' was not declared in this scope
__disable_irq();
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:189:3: note: suggested alternative: 'uhd_disable_sof'
__disable_irq();
uhd_disable_sof
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h: In destructor '__Guard::~__Guard()':
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:193:4: error: '__enable_irq' was not declared in this scope
__enable_irq();
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:193:4: note: suggested alternative: '_rename_r'
__enable_irq();
_rename_r
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/SAMD21_USBDevice.h:195:4: error: '__ISB' was not declared in this scope
__ISB();
In file included from C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/USB_host.h:23:0,
from C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/Arduino.h:159,
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/samd21_host.h: At global scope:
C:\Users\Miguel-iyo\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.5.11\cores\arduino/USB/samd21_host.h:26:49: error: 'UsbHostDescriptor' does not name a type; did you mean 'CDC_GetDescriptor'?
extern __attribute__((__aligned__(4))) volatile UsbHostDescriptor usb_pipe_table[USB_EPT_NUM];
CDC_GetDescriptor
exit status 1
Error compilando para la tarjeta Adafruit Grand Central M4 (SAMD51).
Migueliyo
by dastels on Fri Apr 10, 2020 3:31 pm
This is the crucial bit:
Skimming over the errors you're getting just confirms it. They primarily relate to low level hardware details, which are going to be significantly different between the AVR and SAMD architectures. It will no doubt take some work and knowledge of the two architectures to rewrite.
The alternative is to either find software that's compatible with the SAMD51 or get an Arduino Mega2560.
dastels
by Migueliyo on Fri Apr 10, 2020 5:12 pm
thanks you for your time and information, I think it better...thanks dave ;)
Migueliyo
