I am working on a project with a Feather M0 Wifi and using Visual Studio Code (Arduino Extension) for programming. Opening the serial monitor in VS Code, I do not get any data (using Serial.print()) from the Feather, however, using the Arduino IDE built-in serial monitor, data is received as expected. I tried hterm as another serial terminal, but it also does not receive anything from the Feather board.
Weird thing is when I upload the exact same code to a Sparkfun Redboard Turbo, I get the data over all serial monitors (Arduino IDE, VS Code, hterm) as expected.
My settings are baud rate 115200, 8-N-1 for the serial communication.
Am I missing something that needs to be set up for the Feather, which the Arduino IDE does by default?
No Data on Serial Terminals
- eaglex
Re: No Data on Serial Terminals
Solved the issue:
DTR for resetting the board does not work properly. Dowgrading VS Code Arduino extension to 0.3.0 solved the issue.
See https://github.com/microsoft/vscode-arduino/issues/1063
- adafruit_support_bill
Good to hear you found the solution. Thanks for the update.
