Using the TCA9548A and DRV2605L breakout boards
by aashu1 on Thu Aug 06, 2020 12:01 pm
I am using the TCA9548A I2C multiplexer to communicate with 6 haptic motors. I am using an Arduino Uno to code these components. Each one of these haptic motors is connected to a DRV2605L breakout board, which is then connected to the I2C multiplexer. Since both products are from Adafruit, I was wondering if there is a simple way to communicate to each motor through the I2C multiplexer. So far, I have connected the I2C multiplexer and by running your initial code, have recognized the ports and the DRV2605L breakout boards connected to them. But I cannot get the motors to rotate since I do not know what command to send the I2C multiplexer! I do not know if tcaselect( ) can be used to send a command to one of the 6 vibration motors I am using. Can you please help?
Thank you
aashu1
Re: Using the TCA9548A and DRV2605L breakout boards
by adafruit_support_bill on Thu Aug 06, 2020 12:18 pm
Communication with the DRV2605L is via the DRV2605L library.
https://learn.adafruit.com/adafruit-drv ... -1043645-4
You use tcaselect() to select a channel on the multiplexer. Then any DRV2605L commands you send will be directed to the board attached to that channel.
by aashu1 on Thu Aug 06, 2020 1:47 pm
I am having problems with the setup. While the setup for the TCA9548A is the same that was used in the testing example, how do I set up the motor before I select the port? Could you please help me out with this?
Thank you
#include "Adafruit_DRV2605.h"
#include "Wire.h"
#include <Wire.h>
extern "C"{
#include "utility/twi.h"
#define TCAADDR 0x70
Adafruit_DRV2605 drv;
void tcaselect(uint8_t i) {
  if (i > 7) return;
  Wire.beginTransmission(TCAADDR);
  Wire.write(1 << i);
  Wire.endTransmission();
void setup()
  drv.begin();
  drv.selectLibrary(1);
  drv.setMode(DRV2605_MODE_INTTRIG);
    while (!Serial);
    delay(1000);
    Wire.begin();
    Serial.begin(9600);
    for (uint8_t t=0; t<8; t++) {
      tcaselect(t);
      Serial.print("TCA Port #"); Serial.println(t);
      for (uint8_t addr = 0; addr<=127; addr++) {
        if (addr == TCAADDR) continue;
        uint8_t data;
        if (! twi_writeTo(addr, &data, 0, 1, 1)) {
           Serial.print("Found I2C 0x");  Serial.println(addr,HEX);
uint8_t effect = 1;
  tcaselect(0);
  effect=120;
  drv.setWaveform(0, effect);  // play effect
  drv.setWaveform(1, 0);       // end waveform
  drv.go();
TCA_Motor.ino
(1014 Bytes) Downloaded 1 time
Last edited by adafruit_support_bill on Thu Aug 06, 2020 1:48 pm, edited 1 time in total.
Reason: Please use [code] tags when posting code to the forums
aashu1
by adafruit_support_bill on Thu Aug 06, 2020 1:50 pm
You can't. You need to select the port before you can talk to the device.
by aashu1 on Thu Aug 06, 2020 1:55 pm
I did select the port before I set up the motor in my void setup(). It's still not working. Can you please take a look and tell me if my command to the motor is wrong in the void loop()??
Thank you
aashu1
by adafruit_support_bill on Thu Aug 06, 2020 2:11 pm
You need to give it some time for the command to run. The loop function is called repeatedly, so you are sending it a continuous stream of commands.
by aashu1 on Thu Aug 06, 2020 2:31 pm
Thank you very much for your help! I got it. Turned out I need to add a bit of a delay in the loop and make sure the effect was strong enough to be felt.
aashu1
